Question about Motorola Mobility RAZR V3
Water went in the sceeen therefore it os balabce and we cannot seea nything but everything else is working.
  • 316 Answers
Please leave the phone to dry maybe a couple of days.
If it is working but no screen for now then the longer you have liquid and electicity together the more damage you make.the screen may come back after it dries out but there is no garantees. this sort of thing is normaly the death of a phone
Posted on Nov 03, 2007
0 characters
3 Points
Absolutley EVERYTHING still works just blank screen after dropping in water.
If you put it in water, immediately shut the phone off, pull the battery, sim card (if applicable) and put everything in a bowl of white rice for a few days. The white rice should remove the device enough so everything should be usable.
I've also heard that immediately freezing the phone works too, your choice.
Jun 11, 2011 | Cell Phones
Iphone 3gs, had some water on the screen (not much), i checked it and everything was fine,,, includeing the brightness, then i put it down and didnt think about it,, went back late and the brightness wont...
your screen have been affected with water. When you accidentally drop your phone in water, DO NOT turn the phone on yet instead put the phone in a bag of rice, the rice helps to seep water. Since you turned on the phone already, there is nothing to do but get the phone repaired or replaced.
Apr 23, 2011 | Cell Phones
Hey i have an lg rumour havent had it more than a
does it have water damage at all? also have you ever dropped it? because when my rumor had water damage, the screen went white.
Aug 27, 2009 | LG RUMOR Cellular Phone
Broken screen on lg dare Broken touch screen. can it be replaced? got my phone wet for a second. dried it off. everything works, but my touch screen will not respond on the left side of the phone. water...
ive had a similar problem... but what i did is i looked at what the insurance does cover... since it doesnt cover water damage.. defect the phone in some way that the insurance will cover. its only if you're in desperate need. there is no way to fix water damage... but i know PLENTY of tricks to soak water out of the phone
May 30, 2009 | LG Dare VX9700 Cell Phone
Everything works but the touch screen.
caring for the touch screen includes touching the screen with clean and DRY hands., if your phone fell in the water, it will likely damage the touch screen.. contact your nearest LG repair center.. i hope your phone will soon be fine..
May 01, 2009 | LG Vu Cellular Phone
Phone Immersed in Sea Water = DEAD!
For many years it has been known that Electricity and Water do not go together. Since mobiles work with electricity - although low voltage - it is therefore NOT surprising that your phone no longer works.
Indeed the sea water is not only a very good conducter of electricity so it would have shorted out the delicate componants and that is why it no longer works, it is also very corrosive and therefore would make the phone unrepairable.
I'm afraid the only answer is to get a new one..
Nov 12, 2008 | Sony Ericsson K850i Mobile Phone
Flash stuck on LG VX6100
If it survived one dunking it will most liklet survive a second SOOOOO. I am into R/C stuff and when our gear gets dunked we rinse it out with ultra pure water, Deionised/distilled water if you can get it. I think that the detergent in the washing machine may have left a residue and be affecting your electronics so if you wash it carefully in distilled water (yep dunk it again, crack it open and wash it all inside)to get rid of the detergent residue on the board (note REMOVE BATTERY). Afterwards dunk it in methylated spirits (test to make sure it wont affect any plastic parts first)to remove the water and leave to dry in a warm spot for a day at least. 2 years ago I dropped a $500 transmitter in a dirty dam (Acid /fuel/road runoff)and did exactly this and its been fine ever since. Worked the next day in fact. Its not a mobile phone but its always worth a chance. Once you've finished you may want to take it apart after you've tested it if its going and spray the board with CRC 226 circuit cleaner and water repeller. I've got it on all of my R/C gear and it gets regularly soaked for up to 1hr at a time in muddy water and is all fine.
Apr 30, 2007 | LG VX6000
Motorola Mobility RAZR V3 Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
