Question about Razor MX350 DIRT ROCKET - BLUE
Bike is fully charged but when you crank the trottle bike just won't move
5 Suggested Answers
billfox1966
  • 231 Answers
SOURCE: wont run but is fully charged
the throttle is a voltage resitor and either needs cleanded with electa clean elictical parts washer or it need replaced all together.
Posted on Jul 10, 2009
albertjunior
  • 56 Answers
SOURCE: The bike says that it is fully charged but is very
the battery is bad....because of over charge....u need a new one!....
Posted on Oct 06, 2009
SOURCE: off-on switch as bright as when it was new. green
On n off switch on bike wont stay on. U can turn it on when charger is hooked up to it but once u take plug out red light goes off.
Posted on Jan 20, 2013
erickedubbs
  • 15 Answers
SOURCE: Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Posted on Apr 13, 2013
Springer classic clicks when trying to start
Make sure the battery is fully charged. Contrary to what some people will tell you, Harley batteries are not fully charged when shipped to dealerships. I work at a dealership and it normally takes a full 8 hour shift to charge a new battery that fits your bike. The clicking sound in normally caused by a low battery. Good luck!
Apr 02, 2014 | 2005 Harley Davidson FLSTSC - FLSTSCI...
Dynacraft Girls 16" Barbie Bike pedals don't move
The problem could be the coaster brake hub, it could be that the cranks are not properly adjusted, or any number of other weird things. My advise--take it to a bike shop. If they're kind, they should be able to get things moving in the proper circular motion quickly for a reasonable charge. If they're not kind, they'll laugh at the bike first, but they will still help.
Dec 28, 2013 | Dynacraft Girls 16" Barbie Bike
2009 Yamaha Vstar 1300 turns over but will not start.
If the motorcycle has not been cranked in a while it could be the carburetors need to be disassembled and cleaned. They may have gummed up.
Oct 07, 2012 | 2009 Yamaha V Star 1300
Battery is fully charged, lights flash, securty lights won't stop flashing but bike won't turn on?
Hi Maritza, for more information about your question please visit the website below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 11, 2012 | 2009 Harley Davidson FXDC Dyna Super Glide...
Hi, my daughter pricess bike won't ride. am not what is wrong. newly prchsed and assemble. please can you help?
will the pedals move forward? they should cause the chain to move and the crank in the back to cause the wheel to spin, if this isnt happening, look at the chain and make sure its correctly on both sprockets, if the pedals still wont spin, they may be too tight on the crank.
May 05, 2011 | Disney Princess 16" Girls Bike Huffy...
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
Jul 07, 2010 | Razor MX350 DIRT ROCKET - BLUE
Rear lights and front turn signal works but nothing else on front of bike works and bike will not start. Battery fully charged
I would start by checking the fuses, but it sounds like an ignition switch. Does the bike crank? Load test the battery. Many times have I seen a battery with a full charge drop to nearly nothing on a load test. If it does not make a sound,check wires to ignition for opens, along with the wiring in the headlight assembly for shorts to ground.
May 01, 2010 | Suzuki Boulevard C50T Motorcycles
Bike wont start
I posted this for a similar problem, maybe it can help. Are you sure it's getting gas to the carbs? Some people don't realize the 99-02 SV650 has a vacuum-actuated fuel pump, and sometimes it can get stuck. Mine has had this problem, and it took me a while to determine it was the problem. I would guess it only happens after the bike has been sitting a while (ours unfortunately sat for a year or so without being run).
Best way to check it is to lift the tank (it's bolted to the frame on the right side of the engine just under the tank). Unplug the line toward the front of the motorcycle from the fuel pump, and connect some spare fuel hose to it running to a can next to the bike (don't want to get gas everywhere!). With everything else still connected, crank the bike for a short period to see if any fuel comes out (shouldn't take long). If not, then move backward and ensure fuel will flow from the vacuum-petcock when the bike is cranked. If that does work, your fuel pump needs some work. I was able to take mine apart and unstick it.
Aug 03, 2009 | 2001 Suzuki SV 650
03 999 wont crank
If the neutral light is not on, try pulling in the clutch and cranking the bike. Also check the kill switch on the bike, that will also keep it from cranking although that should not affect the neutral indicator. If the neutral indicator isn't working you may have to get into the transmission to repair it.
Jan 01, 2009 | 2003 Ducati 999 S
Razor MX350 DIRT ROCKET - BLUE Logo
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
