Question about Casio fx-300ES Calculator
How to change radian to degree mode on the casio fx-300es
5 Suggested Answers
  • 7993 Answers
SOURCE: i need to change to mode to degress
Under the screen you can see atable of values at the right of which is written MODE followed by a small arrow.
If you want to set the degree as angle unit, you press the MODE key followed by 4 (as seen in the table I was referring to).
Similarly, if you want to set RAD as the angle unit you press MODE then 5; and MODE then 6 for GRAD.
However if you just want to convert a number displayed on the screen in RADs or GRADs into DEGs , you press SHIFT then MODE then 4. your number should be converted from the unit it was expressed in into degrees.
Same thing if you want to convert into RADs: SHIFT then MODE then 5.
Hope it helps.
Posted on Aug 17, 2009
  • 7993 Answers
SOURCE: casio fx-300es---how to convert radians to degrees
You use the key combination [SHIFT][ANS] (DRG>).
If the default angle unit is degree
Type in the angle value in radian, say 1.2.
Press [SHIFT][ANS] (DRG>).
The screen displays 1: deg symbol, 2: a raised r for radian, and 3; a raised g (for grad).
1.2 [SHIFT][ANS] (DRG>) [2: raised r] .
The screen displays 1.2 with a raised r to the right of the 2.
Press [=].
The answer is 68.75493542
Posted on Dec 07, 2009
  • 7993 Answers
SOURCE: How do you switch between degree and radian mode
Press SHIFT MODE to access (SETUP)
Press 3:deg for degree OR
press 4:Rad for radian.
Posted on Apr 05, 2010
  • 7993 Answers
SOURCE: how the heck do you change a casio fx-9750II from radian to degre
  1. With calculator turned on, press [MENU] if you do not see icons.
  2. Use the navigation arrows to highlight [RUN-MAT] icon or press 1.
  3. In the Run-Mat screen press [SHIFT][MENU] to enter the (SETUP).
  4. Press the DownArrow 5 times to highlight the ANGLE option.
  5. Press [F1:Deg] to select degree.
  6. Press [SHIFT][EXIT] to (QUIT) the SetUp screen.
  7. Do your geometry ( I would say trigonometry).
Posted on Apr 08, 2010
How to change from degrees to radian mode casio fx-cg10
In Run>Mat screen press SHIFT MODE to enter the setup screen. Scroll down to the line Angle. Press F2:Rad to set angle unit to radian, See Screen capture below.
Jul 06, 2014 | Casio FX-300MS Calculator
How to switch between radian mode and degree mode
Press SHIFT MODE then 3 for degree or 4 for radian.
Dec 04, 2010 | Casio FX-115ES Scientific Calculator
How do you change to radian mode?
Press [SHIFT][MODE] to access (SETUP)
Apr 29, 2010 | Casio fx-300ES Calculator
How do you switch between degree and radian mode on the fx-115 ES Casio calulator? Thanx
Apr 02, 2010 | Casio FX-115ES Scientific Calculator
Casio fx-300es---how to convert radians to degrees
Press [=].
Dec 02, 2009 | Casio fx-300ES Calculator
Casio FX-115 ES: SIN,COS,TAN (answer isnt correct)
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Sep 16, 2009 | Casio FX-115ES Scientific Calculator
Don't know how to change it from degrees to radian mode
if you press the |mode| button (at the top right of the calculator) until you see Deg Rad Gra on the screen (I believe 3 presses of the mode button) and just hit the number below the rad option on the display. This will permanently change it to radian mode until you repeat this step, or clear the memory.
There is also a way to change to radian mode for just one operation if you will be mostly using degrees for example
at the bottom there is a DRG> as a shifted function. I would just recommend changing it in the way I initially outlined as there is less room for error when making calculations.
Apr 22, 2009 | Casio FX-300MS Calculator
How do i input the radian symbol
Multiply it by 180 and then divide by PI.
Feb 23, 2009 | Casio fx-300ES Calculator
How do I get decimal answers
I had the same problem. To change the output to decimals, do the following:
Go to Math mode, then SHIFT, MODE (set-up), 2 (lineIO). This will cause answers to show in decimal format. I hope this helps.
I was able to find a manual at: http://www.generalmanual.com/Calculators/Casio-FX-300ES-Scientific-Financial-Calculator.htm
Nov 06, 2007 | Casio fx-300ES Calculator
Casio fx-300ES Calculator Logo
166 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
