Question about Garmin Forerunner 310XT Handheld GPS Receiver
Garmin 310xt will not charge
When the watch is connected properly to charger and plugged in to an outlet the watch will charge
sharcnet
  • 2130 Answers
SOURCE: garmin charger problems
19A259741 is the serial number. The model number should be to the left of that on the decal label. It's sounds like you have a Nuvi 2xx series.
The mini-USB jack is loose. Either is has come loose from the board or the connections within the jack are loose from everyday wear and tear (use).
If the jack is loose from the board and it needs to be resoldered or replaced if the jack is worn out.
- Jim
SHARCNET-USA
Posted on Dec 05, 2008
SOURCE: Garnin NUVI 680
Needed to change the fuse
Posted on Mar 26, 2009
  • 31 Answers
SOURCE: Garmin died and will not turn on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
SOURCE: won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
Posted on Aug 06, 2009
SOURCE: How to charge Garmin 755t
I had the same problem with mine & it was only 6 months old. The battery needs to be replaced. This is a good site that shows you how to change the battery & you can order the new battery from them as well. http://www.newpower99.com/
Posted on Apr 24, 2010
Training sessions will not upload with Garmin Express.
I solved this by uninstalling all usb root hub drivers on my pc through device manager and rebooting to allow them to be re installed.
They were all reporting as working correctly but something must have been confused because on rebooting all was well.
Sep 22, 2014 | Garmin Forerunner 310XT GPS Sports Watch
Ant will not pair with my 310
Do a master reset and start using Garmin Express
Jul 27, 2014 | Garmin Forerunner 310XT GPS Sports Watch
Garmin 310xt software
Run the Garmin WebUpdater to load or reload the latest software to the device.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
May 15, 2012 | Garmin Forerunner 310 Xt Gps Sport Watch...
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
Stuck on low battery warning. Battery not actually low. Plugging in to charger does not help.
Just turn down you brightness, turn off wifi when possible, and use LEO Privacy to boost your phone and save battery.
LEO Privacy Applock Hide Safe Android Apps on Google Play
Mar 20, 2011 | Garmin Forerunner 310XT Handheld GPS...
Garmin 765t can charge garmin with usb port, however, once garmin is connected to vehicle outlet, garmin will not charge and looses full charge within 30 minutes. fuse is good in vehicle, and works on...
It's most likely that the fuse in the plug of the charger lead has blown. There's a ring at the top of the charger plug. Unscrew this and the plug comes apart. You'll see the fuse inside. Be careful not to lose any parts.
Sep 27, 2010 | Garmin nuvi 765T GPS Receiver
Won't turn on or charge
Jul 28, 2009 | Garmin Forerunner 305 GPS Receiver
Garnin NUVI 680
Aug 08, 2008 | Garmin Nuvi 660 GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Forerunner 310XT Handheld GPS Receiver Logo
54 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
