Question about As Seen On TV Finishing Touch Hair Trimmer
Finishing touch battery - As Seen On TV Finishing Touch Hair Trimmer
Tip
How to change your iPod touch and iPhone battery
Batteries for the iPod touch, iPhone, and much more can be purchased from http://www.milliamp.com
Using a thin, but sturdy guitar pick, carefully separate the backing of the iPod from the screen. This may be tough to do because the chrome backing snaps to the touch screen assembly, and care must be taken to prevent cracking the screen.
Once the chrome backing is separated from the iPod, the battery is now exposed.
If the battery has never been changed, it will more than likely be glued in place, and must be carefully removed with the guitar pick as well.
The wires must be soldered and taped with electrical tape, or carefully protected with heat shrink tubing. There is not much clearance available inside the iPod, so keep this in mind when finishing up with the wiring and protecting the wires from shorting.
Carefully put the new battery in the old batteries spot, and snap the chrome backing back together with the front screen.
Charge the iPod for at least 10 minutes before attempting to turn it on, but keep it on the charger until it is fully charged for best results.
on Jan 12, 2010 | Apple iPod touch
How to change the battery in finishing touch
how to change the battery in finishing touch by diamond
Oct 09, 2016 | As Seen On TV Finishing Touch Hair Trimmer
Put new battery now only telling me to touch arrow whereever it moves around screen
thats so the touch pad knows where your finger is, its called calibrating ..just keep touching the arrow until its finished then your touch screen will be set up
May 31, 2015 | Computers & Internet
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
Oct 01, 2012 | Tissot T-Touch T33759851
I own a sony icf sw 7600g short wave radio which worked perfectly until recently when I believe a battery may have leaked and now it is caput with nothing coming on ; dead dead ! is it fixable and can you...
When a battery leaks it leak acid which can damage or ruin everything it touches. First how extensive was the leak? Was it just a bit or did it seep onto the circuit board? You can clean the terminals. Remember your dealing with battery acid. Do it over a metal can and brush the terminals with a small wire brush. (Don't touch your eyes until your finished and have thoroughly washed your hands.) Just like you would a battery terminal. Then when down to the metal again use a regular pencil eraser to finish the cleaning. You may try a drop of flux per terminal as well after using the wire brush. If a wire was negated then soldier a new one in. You can also use a small, dry, non soap impregnated SOS pad in place of a wire brush. Install new batteries and give it a try. If no acid ruined the circuit board it is just an issue of getting the terminals to run current through them again.
Mar 07, 2011 | Sony ICF-SW7600 AM/FM/SW Radio
Finisher setting will not work
touch the additional functions key then touch custom settings scrolll till you find limited function mode touch it then turn limited function off turn copier off then on this should turn the finisher back on unless the finisher has an error
Sep 25, 2009 | Canon imageRUNNER 5000 Copier
I need calibrate Tissot t-touch
Syncronisation sequence is in the user manual. syncronisation is as follows.. 1) Press T to activate touch system. 2)touch the screen centre to show units display. 3)hold T button for approx 5 secs till the hands point to 12o clock. 4)use the + & - buttons to control the minute and hour hands... you must syncronise them both to 12 oclock exactly. 5)when you have them both pointing to 12 exactly, press the T button to finish the sync. the hands will now go back to the time. If the hands often go out of sync, the battery is probably worn and will at some stage the 'bat' warning will appear. (this initially only flashes every 20 secs, so watch the display for over 20 secs to see the 'bat' warning. eventyually this becomes permanant display). Batteries normally last about 6 years
Jun 04, 2009 | Tissot T-Touch T33759851
As Seen On TV Finishing Touch Hair Trimmer Logo
19 people viewed this question
Top As Seen On TV Health & Beauty Experts
Tom Chichester
Are you an As Seen On TV Health and Beauty Expert? Answer questions, earn points and help others
