Question about Honeywell L4064B2236 Fan/Limit Control Heater
Blower motor on a/c furnace not coming on
Outside compressor and fan are kicking on no problem the blower inside does not kick on when a/c does. I have a whirlpool ndgk100dg01. I think it's a relay, but have no idea where it is?
    Sergeant:
  • 340 Answers
Could be a relay possible fan motor try put the fan to on on the thermostat if no fan one of the two relay or fan motor. you'll need a volt meter and know how to use it to solve problem It would be safer to call a contractor. Tom
Posted on Jun 18, 2009
Found wiring diagram online and isolated part, found part online, ordered and replaced! works great
Posted on Jun 19, 2009
How to trouble shoot heat/ a/c fan switch.
Will your blower fan kick on in the medium position by chance? Med/ med high..if it is a 4 position switch, does it operate in the number 3 position? If so it is probably your blower motor resistor. If not, I would test the blower motor itself. Since the compressor kicks on when you turn the fan on, I would think the switch is working.
Jun 11, 2015 | 1991 Toyota Camry
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
What's wrong Blower. And fan kick om outside no blower insid
You have to be a little more detailed on your system. Is it a mini split, a forced air system with a air handle/furnace or something else.
Aug 26, 2014 | Heating & Cooling
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
Why does my fan runs continus. and the condenser won't run out side.
The fan runs continously because your condensor is not kicking on and removing the heat. The thermostat needs to come under the set temp. to kick off the fan. If your compressor doesn't run and the fan on the outside unit does run, your compressor has an issue. If nothing runs outside, then your transformer on the inside unit(air handler) has an issue. This could also be a control relay on the condenser or the air handler.
Jan 15, 2010 | Omega Trane Furnace Draft Inducer Blower...
No forced air.... compressor unit and furnace do kick on
Bad blower motor/capicitor or relay. Check the fuse if it has one.
Aug 11, 2009 | Heating & Cooling
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Kenmore a/c window unit fan not kicking on with compressor.
Likely a bad motor, when this occurs verify the board is sending voltage to the motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 30, 2017 | Kenmore Heating & Cooling
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
Honeywell L4064B2236 Fan/Limit Control Heater Logo
1,177 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
