Question about Panasonic Vacuums
Making funny noise - Panasonic Vacuums
I have a DC25 it works fine, my problem is when I switch It off it makes a horrendous noise like an airplane taking off. I have taken everything apart and cleaned everything but yet still makes funny...
It may be air whistling past the exhaust filter, which may need replaced. Try removing the filter to see if that could be where the noise is coming from.
Feb 12, 2015 | Vacuums
I love my floor mate which I bought last year. Now it is making a funny sound and has a weird burning smell. I was told to take it to a repair shop but before spending the money I want to find out if this...
It may be the belt. Sometime the motor spins but the belt is not spinning with it. This causes the belt to heat-up and burn/melt. The burned rubber maybe what you're smelling and sometime make funny noise and hard to push the vacuum.
Oct 08, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Dyson is making funny noises
That's the clutch. An extremely hard piece to replace. Your vacuum is pretty much a paper weight.
Mar 21, 2010 | Vacuums
8910 is making a funny noise. maybe clogged?
Could be, but it could also be from the seals if they are old and need to be replaced. They are rubber strips (like used in some screens), and can make a horrible noise when they need to be replaced.
Dec 24, 2009 | Bissell 8910 ProHeat Clear View Upright...
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Jim
Nov 29, 2009 | Panasonic Vacuums
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The engine makes a funny noise and the brushes make sparks.
Hi
The bearings are not replaceable. If the bearings have gone you need to replace the complete motor
Mar 09, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Rainbow SE makes funny noise when first turned on.
try putting water into it.if not then you should make sure the seperator is in.or is connected properly
Jan 01, 2009 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
19 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
