Question about Quantum Technology eMachines EL Series Desktop EL1830-E10 1GB 800MHz CL4 RAM Memory Module
Due to high power it is fired - Quantum Technology eMachines EL Series Desktop EL1830-E10 1GB 800MHz CL4 RAM Memory Module
  • 5,631 Answers
Take it to service though I doubt it can be repaired
Posted on Jan 08, 2015
HE70ER-L Are there any recalls on this Haier Dehumidifier model?
Results
Dehumidifier Recalls - ConsumerAffairs.com
https://www.consumeraffairs.com/dehumidifier-recalls
  1. Cached
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC). December 30, 2009 LG Electronics is recalling about 98,000 portable dehumidifiers. The power connector for the dehumidifiers compressor can short circuit, posing fire and burn hazards to consumers.
Humidifiers & Dehumidifiers Recall List by WeMakeItSafer
wemakeitsafer.com > ... > Home & Garden > Temperature & Humidity Control
  1. Cached
  2. Similar
Danby, De'Longhi, Fedders, Fellini, Frigidaire, Gree, Kenmore, Norpole, Premiere, Seabreeze, SoleusAir and SuperClima Dehumidifiers. A recall was issued on 2013-09-12 due to a potential fire and burn hazard.
Dehumidifier Recall: How to Find Out if it Affects You
learn.compactappliance.com > A/C & Heating
  1. Cached
  2. Similar
Jun 12, 2014 - How to Find Out if Your Dehumidifier Was Recalled. ... Many popular brands known for having high quality dehumidifiers such as Danby, Frigidaire, and Soleus had models affected by this recall. ... Brands have taken different approaches to how they have responded to the Gree dehumidifier ...
Dehumidifiers recalled after overheating, fires - USA Today
www.usatoday.com/story/money/business/2014/.../dehumidifiers-recalled.../9145635/
  1. Cached
  2. Similar
May 15, 2014 - Appliance manufacturer Gree has issued another recall for a line of its ... .cpsc.gov/en/Recalls/2014/Gree-Reannounces-Dehumidifier-Recall.
Public Notices ' Haier America
https://www.haieramerica.com/public-notices
  1. Cached
Product Recalls. The latest public notices can be found here. Recall Date. Haier America Expands Recall of Chest Freezers Due to Fire Hazard, Sunday, May 12 ...
Nov 07, 2016 | Haier Dehumidifiers
Have a carrier furnace model 58DHC095.it go thru its normal cycle for heat but the fan wont come on until the cycle end and furnace over heats. the fan works on all speeds and I have replaced the cont
There has to be a mechanical thermostat and it is sticking or other wise defective. I don't think that the control board is defective because it finally does turn the fan on. However the mechanical thermostat is there to prevent the fire box temperature from getting too high before the fan starts, but there must also be a over heat thermo disc that will shut the fire off when the fire box gets too high.
Oct 11, 2014 | Heating & Cooling
My 1998 hitatci tv keeps blowing fuse whats wroung
The TV has two power supplies, low and high voltage. Most likely the high voltage transistor (called a Horizontal Output Transistor or HOT) is shorted due to a malfunctioning high voltage transformer (the biggest piece on the board with the large red wire coming from it. If the low voltage is bad most likely the diode pack (full wave rectifier) or the voltage regulator chip.
Remember fuses are to keep the unit from catching fire by opening up when a short circuit draws too much current. If you cannot replace the cause of the current draw, it's time to buy a new TV.
Feb 27, 2014 | Televison & Video
My toyota 5e engine backfires
Engine back fires due to:
- Wrong heat range of the spark plugs.
- Spark plugs gaps too wide.
- High tension cords defective.
- Rotor, distributor cap or distributor assembly defective. (Only on distributor type ignition system).
- Ignition coils.
- Fuel pump pressure too high. (regulating valve stuck closed).
Aug 24, 2013 | Toyota Corolla Cars & Trucks
Backfires starting
- Ignition coils.
IBM wont wake up
Unplug, remove battery, Plug in, reboot, Open the Control Panel, select Power Options, Select High Performance, you didn't supply the Model of IBM or the OS, so I'll give you a Win 7 solution, open Change Plan Settings, under Plugged in, select Never and Never, select Advanced Power Settings, Adjust Sleep and Hibernate to Never, adjust ALL settings to your preference. Always shut down and unplug your machine when not in use, it will last longer and prevent damage due to a power surge, and IF your Battery malfunctions COULD prevent a fire hazzard.
Feb 26, 2013 | IBM ThinkPad Computers & Internet
My 7year old kenmore microwave 721-62462 occasionally would buzz and flash behind the metal panel on the side of the microwave. This would happen off and on but without any real rhyme or reason. Today it...
ther is a high voltage generator to generate enough power to the magnetron to produce microwaves, it was probably ARCHING voltage to the body of the oven due to a faulty insulator and the paint caught on fire... as for using it well DON'T it is not safe, and will cost more to repare than a new one
Sorry!
Jan 05, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
Teledyne laars pool heater llg175 turns on burner on for 10min then shuts off before heating fully, bay-pass valve checked ok . Pool heater pressure switched replaced.
Hello,Sounds like it is overheating due to restricted flow.If it is shuting down due to pressure.Maybe high limit?If it is oil fired try reducing the nozzle size/input.If gas you could reduce input pressure 1"WC.
Apr 20, 2010 | Heating & Cooling
Recall Mercedes-Benz SLR McLaren
DaimlerChrysler has announced that it is recalling 2005 and 2006 Mercedes-Benz SLR McLaren models due to a problem with the electrical system. The $450,000, 617-hp car with a top speed of 208 mph could catch fire due to the high temperatures generated by the electrical system and the resulting damage inflicted upon the vehicle's alternator. So far, no fire or accidents have been reported. The recall affects 433 vehicles in the United States, and will involve replacing the alternator and installing a modified control unti. Vehicles elsewhere in the world are being dealt with as well.
May 14, 2008 | 2006 Mercedes-Benz SLR McLaren
Quantum Technology eMachines EL Series Desktop EL1830-E10 1GB 800MHz CL4 RAM Memory Module Logo
47 people viewed this question
Top Quantum Technology Computers & Internet Experts
David Payne
David Payne
Are you a Quantum Technology Computer and Internet Expert? Answer questions, earn points and help others
