Question about Jura Capresso ENA 4 (13421)
How do I remove and replace the grinder? - Jura Capresso ENA 4 (13421)
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
No steam pressure help
see this causess and proceed .God bless you
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Lello 45920 Ariete Cafe Roma Deluxe...
Krups grinder 223
what problem do you have?
Sep 25, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder mod 233
see this causes and proceed .God bless you
Ids77 electric coffee grinder I want replace fuse how can I open this prodact please.
see this causes and proceed:God bless you
Sep 25, 2012 | Coffee Makers & Espresso Machines
How do you change the blade? I bought a new one but can't get the old one off. Thanks
    • 1 Unplug your Krups grinder from the wall.
    • 2 Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.
    • 3 Put your safety gloves on and then grasp the blade of the grinder with your channel locks.
    • 4 Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.
    • 5 Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut.
Things You'll Need
  • Cloth
  • Safety gloves
  • Channel locks
  • Pliers
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Krups 203 Grinder
How do you replace the brushes on a model 1375-01 angle grinder?
unplug tool and on the backside you will find a #2 posidrive screw and remove it and pull the back section off to expose the back of the motor and what I do it move the brush spring to the side and remove the shunt and remove the brush making sure to replace the spring, after doing both slide the back housing on and replace the screw. Let me know if you need more assistance.
Feb 19, 2011 | Bosch 4 - 1/2" Small Angle Grinder
Mr coffee IDS55-4 suddenly stopped working. The blade is intact. What could br the problem and what can I do?
Circuit protection in this grinder is done with a resettable fuse. Mine failed the first time I used it. Fortunately, it's relatively easy to replace.
  1. Remove the plastic plate covering the bottom of the grinder. It is held in place by three screws.
  2. Remove the power cord strain relief inside the grinder. It is held in place with two screws.
  3. Remove the motor. It will only come about half way out of the enclosure.
  4. My fuse was fastened to the motor with a copper tie, which needed to be loosened to access the fuse.
  5. Remove the fuse by un-soldering one end from the motor and clipping the wire that it is crimped to on the other side. See attached photo of the fuse after it was removed.
  6. Replace with a 15A fuse or just solder the end of the black wire directly on to the motor. If you don't replace the fuse, you should be careful not to run the grinder for prolonged periods of time because your may destroy the motor.
Oct 06, 2010 | Mr. Coffee IDS55 Electric Blades Grinder
Cuisinart SS Grinder
try www.smallappliance.com for a replacement.
Nov 02, 2007 | Cuisinart SS Grind Central, removable bowl...
Jura Capresso ENA 4 (13421) Logo
49 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
