Question about Advent Computers & Internet
Laptop blank white screen when booted flashing
Advent monzav200 laptop shows white flashing screen only works when attached to monitor no visual on laptop
harvester3
  • 181 Answers
SOURCE: Blank LCD Screen
Well, sounds like a couple of things if an external monitor works. First, toggle a couple of times between lcd and external just to make sure that it's not set to external only.
If that's no help, look closely at the lcd while the operating system is running. Can you see any image at all? If so (or if not) you have a bad inverter (we have them at the shop for around 25.00). The other possibilities are a bad backlight (which means a new lcd, about 75.00) or it's possible the lcd cable has simply came loose from it's socket.
That's about all it could be on these models if you're getting an external image. I'm using a T30 right now. They tend to have bad memory slots, but great machines.
Good luck
Posted on Nov 26, 2007
DCSE
  • 191 Answers
SOURCE: screen problem
if the display on the external monitor is fine in that case it is an issue with the LCD as you get a video output on external monitor
you have to get the LCD either repaired or replaced.
Posted on Jun 10, 2008
sabharish
  • 297 Answers
SOURCE: blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Posted on Jun 26, 2009
SOURCE: My laptop display only shows half a screen. The
i have solve the problem for my hp nx7300. mine used to show everything that should be shown on the screen but had the screen placed in a Conner so small. i solved this by uninstalling the monitor and unknown device drivers. i have then installed the unknown device as a blue-tooth adapter to avoid this problem recurring. hope this sorts out some people's problem. the other half screen with half completely not shown has to do with the cable connecting the monitor and the CPU. remember solving this for my friend by cleaning the connection port.
Posted on Sep 05, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Posted on Nov 05, 2009
Al1916w acer monitor screen coming white
If you hold a flashlight to the screen when you turn on the laptop,do you see your windows booting up in the dark?
Aug 13, 2014 | Acer Computers & Internet
Blank screen
Did the laptop boot up all the way except the screen is blank? Do you hear fans running and the hard drive spinning, lights on? If you think it booted except the screen is blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 23, 2012 | Computers & Internet
When I turn on the aspire one note book it goes to a white screen and will flash once and go to white screen and stays there, owver all other lights on the panel flash normal, but will not boot up. this is...
If you're still under warranty, you can diagnose one possible problem easily enough. Blank white screen with the LED indicator lights running normally otherwise will almost always mean that the LCD panel is bad. If you don't have an external monitor available, find a friend with one and hook up the laptop to that monitor. Be sure to have the laptop power off when you attach the monitor cable. Press the power up button and then the Fn+F? (whatever F key has a little icon on iyt showing a monitor) combo to switch to an external monitor. If your laptop's Operating System shows up on the monitor, you know for certain it's jus your LCD panel that's bad and you can ask the manufacturer to replace it.
Dec 05, 2009 | Acer Aspire One PC Notebook
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
Dropped and screen went black.still turns on but the screen doesn't work
Attach and external monitor and boot the machine. If you don't have one, ask around your friends and family... someone has a monitor.
If you can see stuff on the monitor when it boots, but when you boot with no monotor the laptop screen is blank, then you most likely have a dead lcd panel on the notebook. It would need to be replaced.
If the external monitor also shows nothing during boot then you likely have larger problems.
Aug 09, 2009 | HP Pavilion dv9000z Notebook
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
HP Compaq NC6220 won't boot
I'm running into the exact same issue. Were you able to resolve the situation?
Fatima
May 16, 2009 | HP Compaq nc6220 Notebook
Advent T2310 laptop screen blank
Have you tried it with an External monitor?
Mar 09, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
Top Advent Computers & Internet Experts
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
