Question about Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner
The belt keeps coming off - Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner
Why does the belt keeps comming off
Hello! If your belt keeps coming off, this usually means the belt is stretched and needs to be replaced. The Dirt Devil Breeze takes a Dirt Devil style 4 belt. Follow the link below to purchase the replacement belt. Hope this helps!
Style 4
Apr 28, 2014 | Dirt Devil Breeze Bagged Upright
Belt keeps coming off
I believe there is something wrong with the roller, could be the barrings or the end caps are warped. Try this, take the roller out and with each hand on each end hold the roller and try to spin the roller with your thumb. If it does not spin freely the problem is the roller.
Nov 20, 2009 | Dirt Devil Featherlite Bagless Vacuum...
A belt will come off for several reasons.:
Wrong size or stretched... should be changed ever 3-6 months.
Misaligned pulley on brush or idler pulley on 2 belt unit
Misaligned motor.. this is rare
Put in a fresh matching genuine belt and keep a spare handy. Belts stretch and slip long before they break
Nov 06, 2009 | Panasonic Vacuums
Belt Keeps Coming Off
Replace the belt with afresh, proper sized one. Yours is stretched. It will be shiny on the underside. hoover belts are meant to fit snug. Check the bearings on the end of the brush roll to remove dirt and thread. The proper belt will need to be stretched into place using the brush for leverage. Likely that your low carpet is more dense causing enough drag to throw the stretched belt.
Sep 13, 2009 | Hoover U6616-900 WindTunnel Bagless...
Hoover Wind Tunnel - Belt Keeps Coming Off
This is the same problem I had. We took it to a vacuum repair store and they fixed it for $80.00!! It lasted about 6 months and it just happened again. I'm not spending the money - I'm looking for another vacuum cleaner.
Apr 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel - the belt keeps coming off & it is the correct
One compatible belt that I use and works (at least while its new) is Royal 104425001. Try that.
Mar 01, 2009 | Hoover S3765-040 WindTunnel Bagless...
Vacumm Belt keeps coming off.
stick a little bit of tape on the inner half of the spindle, this will put an angle on the belt and should prevent it slipping off.
Dec 23, 2008 | Hoover Vacuums
Great. Glad to help.
If you would, take a moment to rate this solution. Thank you. Happy vacuuming. :-)
Oct 25, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Oreck belts keep coming off
If the pulley on the brush roll is worn, then I would replace the brushroll. Look at the ends where the brush roll sits in to make sure the casing hasn't over heated and not holding the brush in place. Also make sure the motor is shifting and causing the belt to come off. Another is if you are catching a rug or towel, that also will cause the belt to come off. I am assuming you using a new belt and not a worn one. After only a short time, belts stretch and need to be replaced.
Jan 22, 2008 | Kirby G5 Bagged Upright Vacuum
Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
