Question about Sony DAV-HDX500 System
CD STUCK CD IS STUCK. PLAYER WONT OPEN GEARS DO GO AROUND
CD player "bad disc" CD stuck in
Use a plastic object to get under the disc while hitting eject. sounds like the gears are skipping or off.
If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
Nov 09, 2013 | Ford Escort Cars & Trucks
I have a 1993 Lexus SC 400 with a Nakamichi sound system. The 12-disk CD player in the trunk has a problem. CDs won't play because they get stuck halfway between the CD carrier and the internal part of the...
remove that cd carrier and replace it with a proper one that fit that place.
u might need to make it in ur own take the mesures and make one its easy u the man!!
follow me rate me!!
Aug 16, 2008 | Nakamichi Car Audio & Video
Dell studio one optical drive makes a chattering noise and ejects the cd after 2 seconds
Although you will rarely be able to repair your own CD player, you may be able to diagnose problems.
That can help you decide whether to have it repaired.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens.
Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work.
Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.
Check for a stuck CD if the drawer won't open or close or will only partially open or close.
If there isn't one, have gears and belts replaced.
Lubricate the gears if the CD player will only play certain tracks or up to a particular point on a disc.
Look for broken plastic parts, such as gears and clips.
Look for loose or broken internal connections.
Have the power supply replaced if your CD player overheats.
If your player won't recognize a disc, make sure the CD is properly loaded and not scratched, and that the lens is clean.
Hope this helps.
Nov 25, 2012 | Dell Studio One 19 PC Desktop
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
CD player will not open
is there power? if there is and it does not open then probably something is either stuck in it or the gear is not any more functional due to gear issues or the motor of the gears are not anymore responding.
When ejecting does seem like it is trying to open but it won't then it is a gear issue, I do not suggest prying it out.
Have it opened and checked for something that can be stuck or if the gears are somehow damaged or not properly seated in their place.
Have it serviced for checking possible this is just a gear issue and the player may still be working and in tact.
Jul 23, 2011 | Audio Players & Recorders
Cd player stuck open. Also need a wiring guide.
gears could be broken, do not push in, you will need to reset the cd player and open the unit up to see whats jamming it.
Feb 14, 2010 | Panasonic SC-PM533 Shelf System
Alpine Mp3/CD Player
hmmm if you bought the alpine deck originally your best bet might be to call them, and see about getting it properly repaired. otherwise, check craigslist or ebay for broken alpine decks with the tilt function. should be pretty easy to fix. also you could open up the cd player and check to see if maybe something just slipped off.
Jul 28, 2008 | Alpine CDA-7892 CD Player
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
The face won't open
Can you pull the face out? If there is no sound at all coming from the head unit (besides the beep) there's a good chance the gear motor that controls the movement of the face is stuck or burnt. Now if there's a clicking sound, the gears may skipping which can be wear'n tear or misaligned gears. I wouldn't call you player done for though. I would take it out, inspect the motorized face machanism and post what you see.
Jul 26, 2007 | Dual XD7600 CD Player
Almost fixed
Could be a weak drive motor or binding gears
Jan 14, 2018 | Spectra SS250 DVD Player
Sony DAV-HDX500 System Logo
52 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
