Question about Ovens
Bottom oven does not work tim eflashes and gives 0-.-7
Defy gormet gemini bottom oven does not work. the time flashes with an error measage 0-.-7
Child lock is activated go to http://www.defy.co.za/images/manuals/OPERATING%20PROCEDURE%20FOR%20DEFY%20GEMINI%20%20OVEN%20%206%20BUTTON%20CLOCK-TIMER.pdf last page.
Posted on Jun 06, 2016
milten1
  • 1304 Answers
SOURCE: Our mayatag gemini oven does not heat on the top
welll the first thing oi would check is my breaker
then check your out let
120 on both sides to ground
220 scorss l1 and l2
then check your terminal post,,, make sure all your connections are tight and secure..
although rare you may have a problem with your erc,,, but usually not with both ovens at the same time
more than likely you have an electrical issue
Posted on Oct 25, 2009
heatman101
  • 43501 Answers
SOURCE: Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 26, 2010
SOURCE: Defy thermofan flashing 0.00 and auto. I've tried pressing key 4
Hi
Can somebody please help
Thanks Terry
Posted on Jun 19, 2010
heatman101
  • 43501 Answers
SOURCE: I have a maytag gemini double oven and the bottom
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jul 30, 2010
SOURCE: The bottom oven of my
I cant find the fuse please can you post more details
Posted on Jul 27, 2011
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
I have a defy Gemini gourmet double oven. The top oven works but no light. The bottom oven there is nothing not even the clock is working. What could be wrong and how do I fix it?
First check and make sure you are not in Sabbath mode in the manual. if you are not in that mode then most likely your oven went over temp and the thermal fuse shorted out. You would need the fuse and most likely a temp sensor because it went over temp. I am not there to do tests but that is what is most likely.
Jan 18, 2016 | Ovens
My Defy Gemini oven does not heat up beyond 80 degrees C when on conventional baking? What could be the problem?
Check to see if the thermostat is plugged in under the cover inside left of door
Dec 03, 2014 | Ovens
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
I bought a house with a Defy Gemini Petite Chef oven but it is not working. The oven flicker on Auto. How can I delete the Auto?
Most models won't work when on Auto. There are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). From left to right numbering the buttons 1-6, this is button 4 on your appliance. Press this button and it should go back to manual mode and allow you to use the oven.
You can download a manual for this appliance from here:
http://www.google.co.uk/url?sa=t&source=web&cd=1&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.defy.co.za%2FgetFile.asp%3FPath%3DD%3A%255Cinetpub%255Cwwwroot%255Cwww.defy.co.za%255Cimages%255CManuals%255C061_896_Gemini_Petit_Chef.pdf%26File%3D061_896_Gemini_Petit_Chef.pdf%26Size%3D342953%26Name%3D061_896_Gemini_Petit_Chef.pdf&rct=j&q=Gemini%20Petite%20Chef%20manual&ei=WfAWTqmnOsmYhQeotZHMBQ&usg=AFQjCNFC3Mdb5clrC_aHL8sq4P0zkfhmZA
Or google " Gemini Petite Chef manual " and the first hit has the link
Jul 08, 2011 | Ovens
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Hi
Thanks Terry
Jun 01, 2010 | Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
244 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
