Question about HP W19b LCD Monitor
What is auto config - HP W19b LCD Monitor
Mijn beeldscherm blijft steeds auto config
Elke monitor heeft een menu-optie. Zoek met uw handleiding hoe u uw menu-opties voor uw specifieke model en daar toegang te krijgen is een optie om berichten of waarschuwingen weer te geven. U **** het uit daar.
Jun 20, 2012 | Acer LCD Monitor P193W
When my computer starts it shows message" Auto config please waite" how can I stop this message as it slows down start of computer.
The message you are describing comes from your monitor. The auto config is the screen automatically resizing to match your computers resolution. You will have to consult the instruction manual for your monitor to see if this feature can be disabled.
Mar 08, 2011 | iiyama AS4611UT 18 in. Flat Panel LCD...
Acer 1916w Auto config. problem, every 5-10seconds, re-adjusts, makes it almost impossible to watch. any ideas for the DIY guy? thanks!
Obviously you've checked the connections are secure both sides? - thats the usual culprit.
Otherwise take it out and leave it off (power unplugged also) for minimum 5 minutes and that will clear any memory and capacitors, then try again.
Oct 29, 2010 | Acer AL1916W 19" LCD Monitor
Auto configation
when do you get this dialog try to run self test on the monitor if same thing happens then change the settng of your monitor to default (factory setting)
Jun 15, 2009 | Computers & Internet
Cisco ASA 5505 Firewall
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
Digital Zoom and Auto Focus "On" settings are not kept/retained
If you shoot in the P mode setting and then go to the Menu and set the option for All Reset to OFF. The camera will retain those settings when powered off. If you are shooting in the AUTO mode the camera will always default back to the factory setting of OFF when the camera is powered off. The All Reset function is not able to be set in the AUTO mode because the camera is already using factory default settings.
Feb 24, 2009 | Olympus Camedia C-765 Digital Camera
Auto Config Please Wait message
Each monitor has a menu option. Find out with your manual how to access your menu options for your specific model and in there is an option to display messages or warnings. You can turn it off there.
Dec 01, 2008 | Acer Computers & Internet
Norcent Monitor problem
yea just let it work i mean when it says auto config it means its adjusting monitor settings accordingly to your hardware nd display so just stay back and wait until it does
Sep 02, 2008 | Norcent Technologies Computers & Internet
Acer auto config
same here never buy a freaking acer
Aug 24, 2007 | Acer AL1715 17" LCD Monitor
HP W19b LCD Monitor Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
