Question about Diamondback Girls Tess 24 Mountain Bike 2013
Diamondback tess 24 has clicking in gears and is hard to shift
My diamondback tess 24 has click noises constantly in the gears and also is hard to shift upwards in gears.
    Scholar:
  • 102 Answers
Sounds like the derailleur cable is stretched out and needs to be adjust. search here or google on how to adjust a derailleur, or take to your local bike shop, it's a cheap repair.
Posted on Sep 25, 2014
3 Suggested Answers
Coachphil
  • 347 Answers
SOURCE: there are gear shifts on
I strongly suggest taking the bike and your son into a bike shop. They will be happy to show him not only how to shift the gears, but why and when. Also they may even throw in some maintenance tips.
The easiest settings will be labeled 1 and the hardest the larger number. if you were too look at the bike where the chain is, the gears that are closest to the frame are the easiest and the ones far away are the hardest. In the back this means the largest gears are the easiest in the front they are opposite, smallest gears are the easiest.
There are a number of good books and many free instructional videos on youtube that show shifting principles. The biggest issue for 10 year olds is whether they can reach the levers comfortably.
Posted on Apr 23, 2011
  • 456 Answers
SOURCE: The gear shifter on the
hi.
these can be adjusted, but the first thing to do is to change the entire gear cable.
spraying the whole thing with wd40 or simillar may help, but the lining of the outer cable has almost certainly worn and is causing the problem you are having.
this is very common. bike makers tend to use relatively cheap cables, and they can wear and cause problems quite easily.
oil the new cable before you fit it and you should not have any more problems.
hope this helps
Posted on Jul 07, 2011
What causes ice maker to make constant clicking noise. This happens in the on and off positions.
The constant clicking noise is probably the neoprene gears within the timer motor itself. Well, sometimes there is a brass 'drive' gear that meshes with a neoprene gear which then in turn operates the mechanical components of the ice maker.
Aug 10, 2014 | Frigidaire Refrigerators
My diamondback gears click and don't seem to shift over
check you derailleur cables, sounds like they have stretched out and you need a little tuneup.
Jul 09, 2014 | Diamondback Cycling
The gear shifter on the Girls' Diamondback Tess 24 is too tight for my daughter to shift gears. She can shift down toward the higher numbers, but getting back up to 3-2-1 is nearly impossible for her....
hi.
hope this helps
Jul 07, 2011 | Diamondback Tess 24 Mountain Bike Girls' ...
Can the handlebars be raised? If so, how?
The handlebars are in a fixed position, they cannot be raised.
May 21, 2011 | Diamondback Tess 20 Girls' FrontSuspension...
There are gear shifts on both handle bars (diamondback cobra 24). How do I instruct my 10 year old how to shift the gears? which is easiest setting and hardest setting?
Apr 23, 2011 | Diamondback Cobra 24 Mountain Bike Boys' ...
I was just given a diamondback SHERWOOD bike. I don't know how to use the gears -- what's the right shifting pattern for hills
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chain line is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you
Apr 01, 2011 | Diamondback Cycling
I have a diamondback serene women's bike, can't shift into 3rd gear. grip turns extremely hard and then if I get the shifter to 3rd, the gears on the bike just click. have to ride it really hard and...
Many possibilities, including derailleur outer limit not correctly adjusted, derailleur not mounted correctly, tight bend or friction in cable. Talk to the store manager/owner about correcting your complaints or find another shop or a bike co-op. If the bike is a major brand from a bike shop (Trek, Giant, Cannondale, etc.) try going to their website, look for Customer Service/Support and enter a complaint.
May 23, 2017 | Diamondback Serene Citi Classic Women's...
Diamondback Girls Tess 24 Mountain Bike 2013 Logo
159 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
