Question about Dell 2355dn Multifunction Laser Printer A4 multifunction n/w mono laser 33 ppm 4.3 INCH Colour LCD Touch screen
Picks up two sheets of paper and one gets stuck in the copier
3 Suggested Answers
  • 749 Answers
SOURCE: printer does not pick up paper sheets
hi,
There are several reason why: The paper roller might be already slippery, which it needs cleaning; The rubber that grips the paper might be also slippery, needs cleaning also; or check the gears at the side of the paper feeder area try to lubricate them... Try all these option and goodluck I know you can fix it by yourself.
Post me more if you have problems....
Posted on Mar 15, 2008
Joed911
  • 4338 Answers
SOURCE: My Dell 1110 laser jet
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Jun 20, 2011
Ink there. My printer does not pick up the paper fron the tray. It only picks it up when I use thick paper and I help it with pushing it into the machine. Always the smart panel telling me there is a paper...
The pick-up roller at the rear of the printer probably needs to be cleaned using an alcohol solution as over time it picks up dirt and ink from the paper being fed through the printer, especially if printing on both side by turning the sheets over.
Oct 27, 2011 | Samsung CLP 300 Laser Printer
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
Printer worked fine. now picks up tons of sheets
A lot of people soon forget to "rifle" the paper before placing it into the bay. This helps prevent the paper from sticking during feeding. Just treat the paper like a book, and flip through the pages.
Jan 15, 2010 | HP LaserJet 2100tn Printer
I have a hp photosmart 2610 printer when it loads the paper it picks up 3 to4 sheets at atime and it jams I am using 24 lb all purpous paper what is the problem?
after time the pickup roller stop picking the paper due to dust coming from the paper, try cleaning all the pickup parts with isopropyl or some other solvent that will not attack plastic
Feb 21, 2009 | HP Office Equipment & Supplies
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
Aug 05, 2008 | Office Equipment & Supplies
Paper feed
Make sure you fan the paper before putting it in. 20 sheets is usually about right for these printers.
If you put labels in the printer. Only put a few sheet in at a time and put paper stock below them.
May 22, 2008 | HP DeskJet 820Cse Printer
MINOLTA PAGE PRO 1250W AND 1350W
Clean rubber roller that picks up paper with isopropyl alcohol. I future, blow the dist off top sheet in stack before printing.
Feb 08, 2008 | Minolta PagePro 1350WN Laser Printer
HP 7110 printer paper rollers
usally when a printer picks up too many sheets the pickup rollers are dirty or covered with paper dust use a microfiber towel moistened with water or rubbing alcohol wipe them off then if it still picks up too many sheets the surface of the pickup roller is worn.replace pick up roller the printerworks .com may have parts or hp partSurfer.com
Oct 20, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Dell 2355dn Multifunction Laser Printer A4 multifunction n/w mono laser 33 ppm 4.3 INCH Colour LCD Touch screen Logo
10 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
