Question about Kill A Watt P3 International P4750 Light Owl
Wont stay off
Motion activated but keeps going off and on all night without activation
The motion light says it has a manual override. I thought this was to be able to turn the light on so it wont shut off until I turn it off. Is this what the manual override means?
Good afternoon Amanda
There is a 'Dusk to Dawn' mode in these lights in which it will turn on continuously for 6 hours once it senses dusk, and then go back to the automated sensing mode for the rest of the night. This is triggered by turning power on and off twice within three seconds. See the manual here (
Defiant MST18920lwdf Use And Care Manual Feature Selection Troubleshooting )
If you follow this link, there is a forum with the same question and a walk-through of how to toggle the switch for manual mode.
how do activate manual mode to keep light on longer on LED Motion security...
That should get you off to the races. Good Luck!
Nov 18, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
I have set all the switches to the left TEST, Low sensitivity and Dual brite OFF and this light stays on all night??
putting the switches on test bypasses all the sensors leaving the light on all the time the test selection is only there to see if the light is working
Jan 15, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
Brinks motion activated security light model 7160w. Only stays on for about 15 seconds. Setting is on 10 minutes. Can someone help?
Sounds like the motion sensor is not picking up motion. Or, does it actually sense motion and only stay on for a short time each time? Try moving the setting, if this is the case and see if you see ANY change. If not, then replace the motion sensor.
Oct 24, 2014 | Home Security
Last night I installed the Utilitech Pro 180 degree Motion activated light. I have the motion sensor sensitivity set as high as it will go but it still doesn't pick up activity beyond 10 feet in front of...
The 48-hour period allows the light to "learn" the operating parameters. The 10-foot range limitation may be due to other environmental factors (such as adjacent bright lights) that affect sensitivity.
Jun 09, 2014 | Home Security
Cooper ms34w wont turn off stays on night an day without movment
Have you had a look at the underside of the motion detector the should be some things for you to a just it with
Mar 25, 2014 | Cooper Lighting Flood Lights. 180 Degree...
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
I would like to rewire a solar security light (motion activated) to stay on at dark. Brand westinghouse
The light will only stay on as long as the battery lasts. My guess is that will not last all night. What you can do is buy a light sensor switch (or even a light sensor socket adaptor is available to save you from having to wire it in) to keep a light on during the night. You can use a CFL or even an LED lamp to save electricity, but it is unlikely that a solar-charged cell will power even one of thes all night long.
Nov 16, 2009 | Solar Motion Security Light Conversion...
Motions don't stay active when doors and windows are on too.
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
Jul 12, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon XT panel lights window, door and motion indicators
It sounds like the auto-stay arming function. Try arming it and opening and closing the door.
Feb 10, 2009 | GE Security Simon 3 Wireless Home Security...
Kill A Watt P3 International P4750 Light Owl Logo
412 people viewed this question
Top Kill A Watt Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Kill A Watt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
