Check page 17 of manual.
FE: OVERFLOW ERROR; Water is overflowing (water level frequency is over 213).If FE is displayed the drain pump will operate to drain the water automatically LG WM2487HM series Service Manual Error Display
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Rather hard to understand your problem from the wording in the question but what I understand to be the case is that your tub fills up with water and overflows after the cycle is finished. Perhaps overnight water slowly fills the tub. This is due to the water inlet valve not shutting off all the way. The Inlet valve assembly needs to be replaced.
Water-inlet valveA defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.Water-level switchA defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
There should be a dome shaped float switch on the inside bottom of the washer. Make sure it is free to move up and down, or is able to float (possibly cracked or broken).
Water-inlet valve Water-level switch Water-inlet valve
Water-level switch
It's underfilling
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect
The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
hi thanks for the question you could have a water valve problem how do you shut the water off by unplugging power cord or shutting off water supply if its unplugging the power cord you have a problem with water control switch or lint is caught in small plastic tube that goes to the water level switch check that could be no parts needed thanks the appliance doc
