Question about Google Finance
Partner van 2002 stops every mile ars so very like fuel
As above
3 Suggested Answers
  • 158 Answers
SOURCE: peugeot 2ltr 2002 partner van turbo diesel HDI
check yhe fuel filter is it new if ok check the fuel pump or lift pump that may bre your problem
Posted on Mar 22, 2009
  • 132 Answers
SOURCE: ABS light flashing when vehicle speed above 10mph
well it looks like theres a problem in your break system somewhere could be the calipers mabey one is sticking or it could be dragging and its a warning i always thought that if the abs comes on then that means your vehicle is performing a duty in order to keep the breaks from locking up due to something malfunctioning.
Posted on Oct 14, 2010
2004 Dodge Sprinter abrupt engine shutdown.
need more info does it run warm
Jan 29, 2014 | Cars & Trucks
My Kia 2002 Sedona has been diagnosed with a
Spark plugs, plug wires, and fuel filter. Pretty cheap, quick, and generally recommended around 100,000 anyways.
Nov 19, 2012 | 2002 Kia Sedona
Engine misfires and hesitation
Ignition Wires on wrong
Worn out Cats --can't test?
140,000 miles & 11 years--replace them
Check Fuel pressure
Front O2 Sensors--not the issue, but get
changed at 100,000 miles
Aug 29, 2012 | 2002 GMC Savana
My 2002 chevy 1500 van , 4.3 liter v6, will not fire. ran great, no signs of trouble leding up to now. Cranks,cranks, & cranks but no sputter, fire, anything
I would check and be sure I had fire to the plugs and fuel to the throttle body. I read what you wrote about the fuel pump but then on the end of the description where you put gas in the van the pump might not be working. If so you could have a bad wire to the fuel pump or a plugged fuel filter. Once you verify those items I would pull the 02 sensor ahead of the catalytic converter in the exhaust and make sure the cat or muffler is not plugged. If they are it will put back pressure on the engine and not allow fuel into the cyl. to fire.
May 23, 2017 | Chevrolet 1500 Cars & Trucks
2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
Mar 03, 2010 | 2002 Chevrolet Express
Partner hdi how far beetween timing belts
According to service manual after 80,000 miles in normal use; or 48,000 miles for arduous use. A lot of stop-start driving is known as arduous use. But to be on safe side, give a call to peugeot dealer and all informations are free of charge.
Jan 09, 2010 | Peugeot Liberte Cars & Trucks
How do reset service light on peugeot partner van
Perform the following
Turn the ignition off
Press and hold the milometer push button (the button for reset the miles mostly the right hand push button on the dash)
Turn on the ignition (do not start the car!)
Wait for the display countdown to reach 0
Release the milometer push button
Turn the ignition off.
Turn the ignition on and check that the correct mileage till the next service is displayed
Jun 05, 2009 | 2005 Peugeot 405
Peugeot Partner Fuel Pump Problem.
If that connection is leaking, then that is more than likely the problem. If fuel is leaking out, then air will leak in. When the van is left overnight, the fuel will run back down the fuel line to the tank, leaving air in the pipe. The fuel system must be completely air tight. Try slapping some grease around the connection and see if it starts in the morning. if it does then replace the connector and you have fixed the problem.
TL
Jan 25, 2009 | 2005 Peugeot 405
Finance Logo
37 people viewed this question
Top Google Finance Experts
Bill Boyd
castletech
castletech
Are you a Google Finance Expert? Answer questions, earn points and help others
