The projector turns on, and after few minute turns off.
It turns green when I put it on, but in 1 to 2 minute turns red. I took out the filter and clean it, but nothing change.
SOURCE: PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
Hey zrscott388, did you end up replacing the bulb and did that fix it? My Z1 is doing the same thing. I hate to spend 300-400 on a bulb and it doesn't work. The Z5 is going for 1100 new on Ebay. I rather do that than waste money. Please let me know.
Posted on Nov 12, 2007
Marrie
  • 563 Answers
SOURCE: Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Posted on Mar 25, 2008
Marrie
  • 563 Answers
SOURCE: vt45 projector turns off without notice.
Hi there
What brand is this Projector ?
Check if the unit has a Filter Timer ? If it does have one - check the hours on it and reset it.
If the problem stil occurs or there is no filter timer in the Menu - check that all your fans are running.
Hope this is of help
Posted on Mar 27, 2008
Marrie
  • 563 Answers
SOURCE: "clean filter" prompt
Hi there
Not at all. This promp automatically appears after a certain amount of hours.
To get this message away , all you have to do is go into the Menu and reset the Filter Timer.
Posted on Apr 15, 2008
  • 17 Answers
SOURCE: Flashing red light
sounds like a flaky power supply or lamp ballast
Posted on Jul 17, 2008
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
Mitsubishi HC2 projector
Was the prvious lamp still working?
Jul 16, 2012 | Mitsubishi HC2 Multimedia Projector
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
I turn on my Sanyo Pro XtraX, with a bulb I replaced about 100 hours ago. The light is red on standy, turns green when I turn it on, but turns off and cools down after just a few minutes. this just started...
This happens to us at work quite often. Usually, it's just that the filters are dirty which doesn't allow the projector to cool and causing it to overheat. We just blow out the filters with a can of compressed air and it solves the problem.
Apr 15, 2009 | Sanyo PLC XU35 Multimedia Projector
Panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Dec 14, 2008 | Panasonic PT-AE900U Multimedia Projector
Warning lights
Just so you know guys (and this procedure is not for the faint hearted!). I had the slow one second red warning light flash. I checked the bulb, which was find and I left it powered off for 48 hours. My projector is no longer under warranty and would have cost me over £300 to have it looked at. I ventured inside to inspect the boards, once I removed the main board to check the power supply I heard movement from one of the light ducts. It took me a while to removed enough to discover the fixing screw which holds the imaging cube in place (which is between the 3 light ducts and the projector lens) had come out (!?) and was rolling around inside the unit. This would also explain why sometimes I could not focus my unit properly. I remounted the imaging cube, put the whole thing back together and PRESTO! My projector is working again.
lee.read@gamil.com
Jun 21, 2008 | Epson EMP 720 Multimedia Projector
19 people viewed this question
k24674
