Question about Refrigerators
Refidgeration section overworking. Auto defrost problem?
SCANDINOVA VESTFROST-DANMARK Type:KF 350, Model: 51
This is a vertical split fridge / freezer with separate compressors for each half. The freezer part works fine. Lately I have become concerned that the fridge section seems to be working a lot harder than it needs to in order to maintain temperature (which it does). It does not run continuously, although it seems to be more on than off, so I have discounted the thermostat. Seals are OK and there are no holes or splits in the internal casing.
What I have noticed is that there is only frost on the rear mounted plate when the compressor is running. Other than then the plate is wet.
Is it feasible that the auto-defrost is stuck on and the refrigerator is fighting, and nominally winning, a battle with its own auto-defrost facility?
If that is possible is there any way to test or disable the auto defrost?
If not possible...any other suggestions?
I'm tempted to go out and but a power consumption meter just to see what power it is burning in a 24 hour period. It is rated, according to the ident plate in the refrigeration section at 1.6kwh / 24h @ 25C (I don't know if that is just for the refrigeration section or the combined unit). I may try switching off the fridge section for 24 hours and seeing if there is a marked difference in overall power used during that period
Any help will be much appreciated.
5 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Posted on Apr 22, 2009
erpaalai
  • 999 Answers
SOURCE: GE TBF 17DB 17,2 cu.ft. refrigerator/freezer runs continuously.
Set both controls to their middle settings. Put a glass of water in the frig with a thermometer in it and check the temperature in 48 hours. I is normal for the newer appliances to be on longer than off. Power consumption is highest during start up and it is more efficient to start less often and run longer. When adjusting controls ONLY change one by one number and wait 24 hours before making another change.
Eric
Posted on Apr 18, 2010
heatman101
  • 43501 Answers
SOURCE: The freezer section won't freeze
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 30, 2010
aviral_srms
  • 1216 Answers
SOURCE: The refrigerator is running continuously
first of all you need to check the coils at the back if they are dirty clean it first.
next thing to check is fans working perfectly or not and then respond me.
Posted on Feb 07, 2011
Fridge started working again after I cleaned the grill, then freezer stoppped, unplugged and waited now freezer is good but fridge won't stay cold. The temp says 56. Ugh! Model # is PLHS67EGSB4.
My Freezer is Cold But My Fridge is Not! - YouTube
? 1:51
www.youtube.com/watch?v=OiKCqniraM8
Nov 5, 2013 - Uploaded by Appliance Princess What to do if your refrigerator is warm, but your freezer is stillcold. ... Cleaning them is a good idea, even if it isn't the cause, because it will improve the fridge's efficiency. ... How does thefreezer fan's failure cause a fridge not to stay cold? .... How To Fix Your Fridgidaire Refrigerator (if the compressor won't ..
Sep 23, 2015 | Refrigerators
Fridge not cold but freezer fine
Can you see frost buildup on the freezer walls? Can you find the model number around the fresh food section door? If you unplug the refrigerator and then remove the freezer panel that has a fan behind panel do you see this? Defective Defrost Heater
With the freezer panel removed can you tell me exactly what type of frost pattern you have? Can you email me a photo of the frost pattern you do have?
Evaporator Frost Pattern Only Two Rows
Another possible problem is your model may have a Auto Damper
that could be stuck because of frost blocking the damper from opening and closing that regulate fresh food section temperatures. If you need help I will be here to answer so please respond and search for your model number so I can possibly look your model and see what type of other features that can cause the freezer to be fine and fresh food section to be warming up, Thanks Sea Breeze
Aug 29, 2012 | Refrigerators
Zanussi fridge freezer. fridge section not working
Check the relay on that model and also check the pressure on freon and see if its up to specs. It may also be a bad trans board .
Apr 22, 2012 | Sewing Machines
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
The top half of the freezer does not work
I have a Scandinova chest freezer and the left hand side froze, but not the right side, because the compressor in the box under the right side of the freezer was getting so hot, a small amount of heat was conducting back through into the right side of the freezer and preventing anything on that side from freezing!
I solved this problem by running the compressor outside of the of the freezer box, by taking the air vent off, unbolting the compressor and then pulling out by about 20cm and running it from there.
Aug 22, 2009 | Freezers
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
