Question about Casio Parts Cash Register PC Desktop
Price subtracted from total.
Department two subtracts the item's total from the total price.
  • 737 Answers
Hi.
Sounds like dept 2 is set as a negative department. You need to change the sign of dept 2 to positive. Should be under department programming in the manual.
Posted on Jun 18, 2009
How do I calculate 20% off
  1. Divide 20 by 100 to convert 20 percent to the decimal 0.2.
  2. Multiply 0.2 by the price of the item to calculate the amount of the discount. For example, if the original price of the item equals $24, you would multiply 0.2 by $24 to get $4.80.
  3. Subtract the value of the discount from the original price to find the price of the item after the discount. In this example, you would subtract $4.80 from $24 to find the price after the discount to be $19.20.
Read more : http://www.ehow.com/how_7541056_calculate-20-off.html
Mar 03, 2015 | Mathsoft Computers & Internet
Luke wants to find the difference 175 - 134. He has subtracted the hundreds and tens so far. What is the sum of the two numbers he has subtracted? How much does he still need to subtract?
SUM means adding not subtracting. so if you were wanting to add the total (the sum) of the amounts of the hundreds and the tens would be 170 plus 130 which would be 300 but the remainder from subtracting 130 from 170 would be 40. That would leave the single units 5 minus 4 of which the remainder is 1. So, the remainder from subtracting 134 from 175 is the reminder of subtracting the one hundred from the one hundred which is zero added to the remainder of subtracting the tens (70 minus 30) which is the remainder of 40 plus the remainder of subtracting the units of 5 minus 4 which is 1. So you need to add the 0 and the 40 and 1 which is the remaining sum of 41.
Sep 19, 2014 | Office Equipment & Supplies
Casio TE-2400 is subtracting 2 pence when I ring through and item and press subtotal- how do I sort this?
It usually means someone has made a mistake while changing prices.
try this:
turn key to program mode
press 0 button
press CASH button
press SUBTOTAL
If anyone has trouble programming the Casio TE-2400 cash register, the programming manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Sep 08, 2012 | Casio Parts Cash Register PC Desktop
Finding original price after percentage taken off
An item costs 46.79 after 20% was taken off the original price so: x-.2x = 46.79 .8x = 46.79 x = 58.49
May 15, 2011 | Office Equipment & Supplies
I want to substract 15 per cent and is not accurate the substraction in this cannon p27 dh brand new. the same operation for adding 15 is ok
To subtract 15% from something, what I do is take the price of the item (let's say it costs $100), then multiply it by 0.15 (which is equivalent to 15%). 100 x 0.15 gives you 15. Then, you'd take that number (15) and subtract it from the $100 to get $85, which is 15% off of $100.
Mar 05, 2011 | Canon Office Equipment & Supplies
My calculator will add, but after my total and then I want to subtract, it subtracts by the number I added.
If your calculator is more of an adding machine it works a little bit differently than a calculator. For an example: 10 + 5 - 2 on your machine do the addition of 10 + 5, then to subtract the 2 press 2 then the minus sign to get the total of 13. I hope this is helpful.
Feb 06, 2011 | Canon Office Equipment & Supplies
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
How to add figures and then subtract from a larger number
use the + key after each number to add the total will appear on screen. When all numbers have been added, enter number to subtract and then press - key. The subtracted number will appear in read on the paper (if two color). and then press the star key to get total.
Jul 08, 2010 | Canon P23-DHV Calculator
Problem coming in subtraction
You just have to use the subtraction formula. The formula is as follows:
=A1 - A2
Where A1 and A2 are cells that contain the data that you would like subtracted. If you want just two numbers subtracted you can type them directly:
=20 - 10
for more information look at the subtraction section of the following link.
http://www.homeandlearn.co.uk/ME/mes5p1.html
Feb 11, 2009 | Microsoft EXCEL 2004 for Mac
Electricity bill coding in java
First think how you would solve this problem yourself on a piece of paper. Then try programming it using the things you learned (if they've given you this assignment without teaching you to multiply, subtract and use if's, drop the course).
Well here is an idea.
Take the total kilowattage and send it to a function. What the function will do is subtract 14KW from the total Kilowattage and add the amount for the first 14KW then subtract 85KW from the total KW and add the amount for the 85KW. But once you subtract the number of KW from the total make sure to check if the total KW isn't negative, if so just break out of the function and return the total due.
Or if you have formula for how much the rate grows over how many miles.
For example lets say the rate grows by $1 every time the KW doubles you could have something like
int rate = 1; //Begining rate
int KW = 14; //First flat rate
int amount; //total amount they have to pay
while(totalKW > 0)
totalKW -= KW; //subtract the first rate
if(totalKW <= 0) //check if too much subtracted
break; //if so break
amount += rate; //add the rate to the total
rate += 1; // Add $1 to the rate every time
KW *= 2; // KW is doubled
Jan 05, 2009 | Computers & Internet
Casio Parts Cash Register PC Desktop Logo
50 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
