Question about Kitchen Appliances - Others
Bunn 2 ultra sensor short
The screen pop up with error message sensor short , the right part did not freeze much
  • 2,237 Answers
Remove the back cowling on that side and clean the sensor boar with canned air (in front right of the motor). check the wires to the sensor for cuts from the metal. remove motor (4 screws) and check board. replace if damaged
Posted on Sep 08, 2014
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: my ultra 2 is not freezing anymore and screen says
Check the back of the machine where the big plastic cover is, you will have to remove the 2 screws back there, and the 2 hoppers as well as the metal platform. When you remove the cover you will notice a mountain of product covering the shaft and the little CPU board back there, clean replace shaft seal and bushing and make sure that the red and white lights on the board have no product on them.
Posted on Jun 30, 2009
projdoc
  • 2237 Answers
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
Why is slush machine only freezing on one side
if it's a cab faby and it's the right side not freezing but getting cold, you have low refrigerant. if it's warm, you have a stuck solenoid, blocked capillary tube, or a bad torque micro switch. if it's a bunn ultra 2, you have a bad solenoid or the freezing button is not on freeze.
May 16, 2014 | Kitchen Appliances - Others
I have a bunn ultra 2 it is reading right side torque sensor error how do I fix it?
Go to page 19 in this repair manual and follow the flow chart to see what is wrong with it and how to troubleshoot it. http://www.bunn.com/pdfs/manuals/41084.0000.pdf
Oct 23, 2013 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
How to fix right side torque error
open the back cowling on the side that has the error (might as well do both) and remove the 4 screws that hold the motor mount to the machine. pull the motor back and unplug it. you'll see an optic sensor board to the right of the shaft on the machine. clean off any dust from the sensors with a q-tip or compressed air. there should be 2 pins on the end of the shaft. if there is only one, you need a shaft assembly. reassemble and test it out.
Oct 23, 2013 | Bunn Margarita Machine Ultra 2 Slush...
I have a 2 hopper bunn ultra 2, both sides are icing over on the outside
the mix is too rich. add some water to each side. it freezes based on torque, not temp.
Aug 17, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Our Bunn Ultra II is just not freezing despite being cleaned. We've checked many things to no avail. Help?
low refrigerant, high brix, no airflow are the most common problem. if it's clean and proper product mix, may have low refrig.
Feb 16, 2011 | Bunn Margarita Machine Ultra 2 Slush...
I have a bunn ultra 2 flat lid ice machine, manual failed to come with the machine. it needs cleaning, the 'clean due now' is always on the screen, followed the info on the side of it to clean and even let...
Can go to the Bunn website.Go to commercial section,then manual index and then specialty drinks.You can find :Illustrated parts,operating service,service,repair and programming.
Oct 16, 2010 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
We were having trouble with one side not freezing so we replaced the shaft seals and replaced a board on the side that wasn't freezing. It now is saying Maintenance due Shaft Seal. is there still a problem...
You need to go through the menu and tell the machine that the maintenance is done, hold down the middle button to get to the menu, then follow on screen prompts and navigate to shaft seal maintenance.
Sep 07, 2010 | Bunn Margarita Machine Ultra 2 Slush...
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
My ultra 2 is not freezing anymore and screen says torque error. how do i fix it?
Jun 29, 2009 | Bunn Margarita Machine Ultra 2 Slush...
Kitchen Appliances - Others Logo
115 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
