Question about Kenmore HE2 Plus Front Load Washer
Mold mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
    Top Expert:
  • Kenmore Master
  • 14,161 Answers
Posted on Jun 15, 2015
What is plastic injection mold mean?
Plastic injection mold is one of the most commonly used molds in manufacturing thermoplastic products. The processing equipment matching with plastic injection mold is plastic injection molding machine. Firstly, plastic is heated and melt in bed charge cartridge heater of injection molding machine. Then, the plastic enters into cavity of mold though nozzle of injection molding machine and gating system of mold, under the promotion of screw or plunger of injection molding machine. The plastic is cooled and hardened for molding, ejected for products. The structure generally consists of molding parts, gating system, guiding parts, ejecting mechanism, exhaust system and supporting parts. Making materials usually adopt plastic die steel, mainly including carbon structural steel, tool carbon steel, tool alloy steel and high-speed steel. Injection molding is only suitable for manufacturing thermoplastic products. Thermoplastic products made by injection molding are quite wide. Daily necessities, complicated machineries, parts on electric appliances and vehicles are molded by injection mold. It is the most widely used in manufacturing plastic products.
Dec 21, 2016 | Cars & Trucks
Removing/replacing right rear molding on 1999 Mercury Grand Marquis
  1. The molding on the right rear of a 1999 grand marqui is simple to remove & does not take any special tools.
  2. The molding has a sticky back on it but can be pulled off by hand.
  3. The ends that stick through the holes in the finder are held in place by a soft epoxy & have to be cut with a knife or razor.
  4. After you cut it, pull it out of the hole & pull the molding out of the grove.
  5. After market molding can be purchased at most auto parts stores.
  6. Make sure to clean all epoxy from the ends & the glue that was on the back of the molding.
  7. Save the old molding so you can cut the new molding in the same way. It comes in a role & not cut individually for you.
  8. hope this helps.
  • Malcolm Sanford
Sep 13, 2016 | 1999 Mercury Grand Marquis
Mold
Techniques for Cleaning Surface Mold
Surface molds grow in just about any damp location, such as the grout lines of a ceramic tiled shower. They\'re easy to scrub away with a mixture of 1/2 cup bleach, 1 qt. water and a little detergent. The bleach in the cleaning mixture kills the mold, and the detergent helps lift it off the surface so you can rinse it away so it won\'t return as fast. You can also buy a mildew cleaner at hardware stores, paint stores and most home centers.
Even for simple cleaning, protect yourself from contact with mold and the bleach solution by wearing a long-sleeve shirt and long pants as well as plastic or rubber gloves and goggles.
If the mold doesn\'t disappear after light scrubbing, reapply the cleaning mix and let it sit for a minute or two. Then lightly scrub again.
Seal the clean surfaces when they\'re thoroughly dry to slow future moisture penetration. Apply a grout sealer (available at tile shops and home centers) to tile joints.
Caution!
Don\'t mix ammonia or any detergent containing ammonia with bleach. The combination forms a poisonous gas.
Read more: http://www.familyhandyman.com/cleaning/mold-and-mildew/how-to-remove-mold/view-all#ixzz39zX8rYj8
Aug 10, 2014 | Tools & Hardware - Others
I have mold on a plaster wall - how do i fix mold on a wall with mold
Clean the wall with bleach and then paint the walls with anti-fungal paint.
If this room is a bathroom then install an exhaust fan to draw out the moisture when you take a shower.
Oct 28, 2012 | Dell Inspiron E6550 Notebook
I have a dometic unit and i smell wath i beleve is mold. i open it up and i see mold? around the blower. how this mold form in the blades? may i get sick breathing this stuff? tank you very much.
Mold can make you very ill depending on which type of mold it is. Mold forms in dark, wet environments and can be hard to get rid of. Your a/c unit needs taken apart and each piece that has mold will need to be cleaned thoroughly and carefully before re-installation.
Jun 22, 2011 | Dometic Rooftop RV Air Conditioner
Brand new toy came without instructions. Please send them for the "made by me!" trademark Power Balls. This is a create your own new product. THANK YOU!!!
The instructions are fairly simple.
1. First, gather your materials. In addition to the kit, you will need a glass (large enough to submerge the assembled mold), water, and a timer.
2. Choose the colors for your ball. Any combination of colors from a single color to several different colors, mixed together, layered, or whatever you can imagine.
3. Assemble the ball mold. The molds come in just two pieces each that snap together easily.
4. Pour the crystals into the mold (make sure they are packed down to insure there are not air bubbles), according to your color design plan. Fill up the mold to complete the proper shape of the ball.
5. Place the filled mold into the glass and fill with water to the top of the ball mold (allow a small amount of water to flow into the top of the mold). Let sit for 5 to 10 minutes.
6. Remove the mold from the water, carefully remove the mold from the ball, and allow to dry.
Tip: A submerging time of 5 minutes is not long enough for most molds; to ensure all the crystals are thoughly wet and a strong ball is formed, 10 minutes is optimal.
Jan 05, 2011 | Toys
Horizon Group Power Balls Super Balls made by me! has no instructions, can you help?
From the box:
Cover work area with scrap paper.
- Decide which shape mold and colors you are going to use to make your power balls.
- Next snap together the two parts of the plastic ball mold
- Open the color crystals package that you would like to use first and pour the desired amount into the funnel on the top of the ball mold. Do not fill the funnel part of the mold all the way to the top or your ball will not bounce very well when you remove it from the mold.
- Holding the funnel part of the mold, carefully place the filled mold in a cup. While holding the mold, fill the cup with water right up to the bottom portion of the funnel. Let the mold sit in the water for five to ten minutes.
- Remove the mold from the water and wait ten minutes before opening it.
- Carefully open the mold and remove the ball. When you remove the ball from the mold it may feel a little sticky. Let it dry until it is no longer sticky before you start playing with it.
- Find a clean, flat surface to bounce the power balls on. When you are done playing, store each ball in resealable bags until you are ready to use them again.
Jan 01, 2011 | Roseart Toys
Kenmore HE2 Plus Front Load Washer Logo
24 people viewed this question
fordexpert
Mike Squire
Robert Rankin
