Question about Sharp LC-32SB23U 32 in. LCD TV
Vertical lines show up on the screen, blocking the programming
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Anything to do for vertical lines on screen?
most likely a damaged sensor. How about the pictures? Do they show these lines on them too?
Oct 23, 2015 | Canon PowerShot ELPH 340 HS Digital Camera...
My HP omni 100 all in one has vertical lines on pictures only, how do I fix this?
In most cases, stationary lines mean the screen is failing. If there is flickering, the LCD cable or a connection could be the problem. If the screen is normal brightness, the inverter is most likely not the cause.
It may only show up only on pictures because they are the only images with solid blocks of color.
Jun 05, 2015 | HP Computers & Internet
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
Screen suddenly only shows vertical colored lines.
this is a problem with your LCD chips you need to replace the optical block to fix this problem and the vertical lines will get worst if you don't replace this part
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 04, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Lp70+ display shows a solid black vertical line
the light tunnel is either collapsing and blocking the light going through it (and needs replacement) or the vertical/hoizontal adjustment of the tunnel. if you take the lamp out and move the colorwheel (with a pencil eraser) to the clear section, you should be able to see a square through it. if part of the square is blocking the middle, the tunnel needs replacing.
by the way, on some projectors the light tunnel is called an integrator rod.
Jun 17, 2008 | InFocus LP70+ Multimedia Projector
Vertical lines
IF the area of the OSD (on screen display) displays the same vertical blue lines as the rest of the screen, then it is most likely the optical block assembly at fault. It's part number is A1606006A and should cost close to $2,000. I'm assuming the set is out of warranty. I know many people are hooked on Sonys, but as a technican that works on them, I wouldn't want one in my home.
Dec 08, 2006 | Sony Grand WEGA KF42WE610 42" Rear...
Sharp LC-32SB23U 32 in. LCD TV Logo
18 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
