Question about Marantec 69190 - Garage Door Opener Photo Eye Safety Beam Set
Fix marantec rpm sensor - Marantec 69190 - Garage Door Opener Photo Eye Safety Beam Set
I need the list of codes for a 1994 corolla
1.6 GLi COROLLA
DTC NUMBER TROUBLE AREA 12 clip_image001.gifRPM signal 13 clip_image002.gifclip_image002.gifRPM signal 14 IGN signal 16 ECT Signal 21 Oxygen sensor signal 22 Water temperature signal 24 Intake air temperature sensor 25 Air / Fuel ratio lean 31 Vacuum sensor signal 41 Throttle sensor 42 Vehicle speed sensor 43 Starter signal 52 Knock sensor 51 Switch COND
Sep 29, 2014 | 1994 Toyota Corolla
Will this work on a martin door?
If the mechanism or motor that lifts the door says martin on it, then no. That opener is made by marantec. This is not compatible with the typical universal keyless systems. Marantec will have a product that is compatible. Another way is to buy and install a reciever kit and then the universal keyless will work.
May 21, 2014 | Universal Garage Wireless Keyless Entry...
All remotes stopped working
You may actually have a problem with the sensor on the garage door. If none of the remotes aren't responding after getting new batteries for them, you may just have to take the sensor in. You could also check and see if the outside remote has any wiring issues, but I honestly think that there is a problem with the sensor and not your remotes. Top Quality Garage Doors At DSI Door Services North Shore
Apr 15, 2014 | Marantec 69190 - Garage Door Opener Photo...
Saturn problem When i first start up my 2001 saturn SL2 1.9 DOHC it will not start up except you pump the gas pedal then it will start up it would stall out you must play with the pedal to keep it running...
Instead of guessing as to what the problem is or looking for a magical fix on here , take an have scan data checked by a qualified repair shop .
047 Engine Hard to Start or No Start Scan Data for Ignition
048 Engine Hard to Start or No Start Scan Data for Starting Problems
What are the fuel trims at ? Do you know what fuel trims are ? Are the O2 sensors switching normally ? What is mass air flow sensor showing ? Map sensor data .? TPS ?
006 O2 Sensor Signal Analysis
002 Fuel Trim Adjustments If you wish to fix your own vehicle running problems buy yourself a good scan tool that views engine sensor data , an check out as much training videos as you can .
Jun 15, 2017 | Cars & Trucks
Omega 4500 garage door opener not working. Tried to program but did not work. Can the logic board be bad ???
Yes, but the remote also may not be the right frequency. The model number you list is, I'm almost certain, made by Marantec. They should have a receiver module that can be removed, and it's about the size of a car alarm remote. You'll see the frequency listed on there. From there, you just need to be sure the remote is the same frequency as the opener.
Aug 26, 2013 | Marantec 69190 - Garage Door Opener Photo...
Hello, I am looking for a marantec keyless entry system
We have no access to any type of part. Sorry.
Oct 14, 2012 | Cars & Trucks
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
My 1999 Dodge Intrepid just died out while driving. Waited a few minutes then it started up. Also, my RPM's recently have been shooting up and down violently while driving. Had valve/hose/plugs change to...
I have the same car is the check engine light on if so have code pulled at auto parts store theres alot of sensors on the car theres a throttle postion sensor the car controls the rpm the computer sends signal to sensors if sensors are starting to go bad rpm will go up and down if the car finds a error in itself it will send a code to the computer of car causeing the check engine light to come on the car stores a error code until problem is fixed if light isnt on then the fuel injectors may need cleaning if its just a random thing its gonna be hard to detect until car stores code good luck
Feb 13, 2011 | 1999 Dodge Intrepid
1992 isuzu trooper 3.2 DOHC 4X4 LOW IDLE GOES UP AND DOWN 750 RPM TO 1500 RPM
I had the same trouble with my 93 Trooper.
I went on a sensor-changing spree.
The one sensor that fixed this idle problem was the throttle position sensor.
You can get one here.
Throttle Position Sensor
It's very easy to change, and fixes the problem instantly.
Good luck.
Jul 22, 2008 | 1993 Isuzu Trooper
Marantec 69190 - Garage Door Opener Photo Eye Safety Beam Set Logo
227 people viewed this question
Top Marantec Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Marantec Building Material Expert? Answer questions, earn points and help others
