Question about Sunbeam Oster Electric Wine Bottle Opener
Oster wine opener has the cork stuck in the screw and come out
The cork is stuck in the screw of the opener. It spins and won't come out
3 Suggested Answers
SOURCE: A cork is stuck in my Oster Electric Wine Bottle
We had the same problem, and we took the thing apart, unscrewed the cork from the corkscrew and put it back together. You have to make sure you line everything up properly inside, though. There are contact points that need to be lined up on the inside.
Posted on Jun 05, 2011
SOURCE: I have an Oster Electric
Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Posted on Sep 01, 2011
My electric wine opener stopped working with a cork in it
Battery has gone flat or it has overloaded the cork screw motor and you will have to cut the old cork off. Try again once changed the battery
Sep 21, 2017 | Home
Oster electric wine opener wont pull out corks. Half of the cork, or part gets stuck up in the unit. Has always worked fine up until day before yesterday. Is is shot? Or cork puller not sharp anymore?
You need to replace the battery pack, pull it out and see what type of cells are used, then build a new battery pack, did this on my own opener and wow it really rocks, lots of power.
Dec 31, 2016 | Oster Refrigerators
Cork stuck in sharper image wine opener
The black plastic ring is secured on the clear tube that you can see the corkscrew through with four little plastic snap tabs. I used a pair of channel locks to gently pull the ring off those tabs. Once you do that you have access to the inside of the clear tube and can reverse the corkscrew and get your broken cork out. Blow debris out and reassemble. Good as new! Even if you break one tab it should still hold, and if you break multiples use some super glue to hold it in place, that will be your last chance to fix it, but at least you've doubled the life of your toy. Good luck!
Aug 05, 2014 | Home
The cork is stuck in the wine opener when I was trying to release the cork after the wine was opened
I used a long tweezers -- about 1 ft long. I held the cork in place, then pressed the reversed button. It came right out.
Feb 22, 2014 | Brookstone Automatic Wine Opener
Cork stuck in wine opener
amazing that noone has answered this question including the people at Waring - I have no idea how to do this
Feb 18, 2014 | Waring Pro WO50 Cordless Wine Opener
Cork will not come out of opener
This is from Jen8926 in another forum and it worked for me (push up the inner sleeve an inch or more inside the main tube): Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Mar 02, 2013 | Waring Pro WO50 Cordless Wine Opener
Waring wine opener wont pull out cork
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
Apr 14, 2012 | Sunbeam Kitchen Appliances - Others
Cork is stuck in Oster open and will not come out the usual wayl
Mar 29, 2011 | Sunbeam Oster Electric Wine Bottle Opener
I have an Oster Electric wine opener. I have half a cork stuck in it that won't come out....any suggestions??
Feb 21, 2011 | Sunbeam Oster Electric Wine Bottle Opener
A cork is stuck in my Oster Electric Wine Bottle Opener.. It spins and spins but will not move up or down. How can I fix this?
Dec 28, 2010 | Sunbeam Oster Electric Wine Bottle Opener
Sunbeam Oster Electric Wine Bottle Opener Logo
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
