Question about Nintendo Game Boy Advance SP Console
Gameboy Advance SP will not charge
When charger is plugged in, the charging light (orange light) will light up for about 1 sec.
I have tried a different charger and i know both are good because I have charged other GBASP units on them.
I have also tried different batteries and i know all the batteries are good cause i have used them in other GBASP units.
I'm guessing this leaves the connector and the charging circuitry, right?
3 Suggested Answers
  • 1082 Answers
SOURCE: My gamboy advance sp won't charge. The battery
I had the same problem. It was a solder connection in the charger socket. I tried to fix it but made it worse. I ended up having to switch the battery with a charged one from another GameBoy. That's how I was able to keep using it.
Posted on Nov 20, 2010
amihasib11
  • 99 Answers
SOURCE: www.nintendo.com
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
a-66
Posted on Jul 23, 2009
My gamboy advance sp won't charge. The battery isn't dead, but the low battery light is on. There is something wrong with the hole the charger goes in. I have several chargers and have tried them all. They...
Nov 20, 2010 | Nintendo Game Boy Advance SP Console
The gameboy wont charge
maybe you have to go to an electronic technician to fix your problem.they have the expertise in opening the gameboy and repair the broken charging port.
Jun 25, 2010 | Nintendo Game Boy Advance SP Blue Console
Other ways to charge a gameboy sp.
hi
you can normally buy a portable charger , it sounds like the pins in the charger have gone ,so it may be a case of buying a new charger these can be picked up on the net quite cheaply
or you could try getting a needle and bending the pins back into the shape they are meant to be , to get an idea look at your other charger
hope this helps
Jan 11, 2010 | Video Game Consoles & Games
Light goes on a for a secongd then shuts off when
When you sed 'I treid removing and replacing battery ' do you mean you bought another battery because you may need to because it sounds like your battery charger has had it, is your SP old though?
Dec 13, 2009 | Nintendo Game Boy Advance SP Console
How to repair gameboy sp advance orange light turns on for a sec then turns off
mines does the same just keep moving the charger around when you charge it or just buy another charger
Jul 22, 2009 | Video Game Consoles & Games
Gameboy not charging
Sounds like the cells inside of the battery are weak and can't hold the charge. If possible, try a known good working battery and then charge it up. If the charge holds and you can run the battery off of it for a while then you know the original battery is bad.
If you try a known good battery and the charge still doesn't hold then it could be the main board inside of the GBA is bad and you would need to get another system unless the one you have happens to still be under warranty.
You can also try a know good ac adapter at that point as well to make sure your adapter isnt flaky but if you can turn on your gba with just the adapter hooked up then more then likely the adapter is good.
Jun 27, 2009 | Nintendo Game Boy Advance SP Console
My GB Advance SP does not charge.
i think u should buy another charger or an other battery for your gameboy
Mar 18, 2009 | Nintendo Game Boy Advance Console
Nintendo gameboy advance sp
i  to had this problem and i know how to fix it.well if you notice when you put the charger piece in the sp the light comes on,and if you were to flick the switch on at just the right moment the sp should turn on for a sec or two. in seeing this you should push the charger in and as soon, i mean ECXACTLY the same time the light comes on it should stay on after a few trys. be patient it takes at least 15 tries for this i promise.
Nov 03, 2007 | Nintendo Game Boy Advance SP Console
Nintendo Game Boy Advance SP Console Logo
841 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
