Question about GE Refrigerators
My in door water quit working on my GE refrigerator model gsh25jfxj
SOURCE: GE Refrigerator model #gss25sgress Water dispenser problem
What you describe was a common problem with this model and one that still pops up. Your refrig *might* qualify for an upgrade under terms of a program GE initiated a few years ago. Call 800-432-2737 first it might save you a service call
Posted on Jan 06, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
aasc
  • 1606 Answers
SOURCE: G.E. Side by side model quit dispensing water
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Posted on Aug 25, 2009
Testimonial: "The diagnostic aid was helpful. Still trying to figure out how to unfreeze the water line in the door of the side by side GE refrigerator, however. "
pilungu
  • 30 Answers
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
My water dispenser quit working any ideas on how to fix or reset it
Mine just stopped also, apparently the water line on certain models is prone to freezing inside the door, (your model is included in the list). After time (in my case 8 years) water migrates into the foam insulation. You can thaw it out with a hair dyer but it will probably freeze again. Here's a link to a part you can get to fix it, haven't received mine yet so I don't know if it works (others say it does). Just call GE and demand that they sell it to you for $20. They will if you're persistatnt Redirect Notice
Feb 22, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
Gsh25jfxj cc
Sounds like it needs cleaning, descaling and a new filter.
May 16, 2017 | GE GSS25JFM Side by Side Refrigerator
GE refrigerator GSL25JFTFBS water dispenser quit working, but ice dispenser still works?
We had a repair man today about exact model and problem. He said the hosed inside he freezer door was frozen. open freezer door and cover the opening with a blanket. Leave open long enough and the water will unthaw and start running again. He said the manufacturers do not pack the hoses in there , they use foam, it eventually gets old and can get shifted to far to the inside. It worked ! working fine now.
May 19, 2012 | GE Refrigerators
I've had a GE Profile side by side (model # GSS25SGPCSS) with in door water and ice dispenser for approx. 6 years. This week the in door water dispenser stopped working. I removed and replaced the filter...
I have the same fridge and the water line freezes up in the door on a regular basis. I have to use a hair dryer and slowly wait for it to melt. It takes about 30 minutes and then works fine for awhile. It has become quite a habit that I'm not thrilled about. Don't waste your money replacing the board or anything else. GE was no help and I'm now shopping for a new fridge bc of this issue. Needless to say that it won't be a GE! Hope this helps.
Oct 09, 2010 | GE Profile Performance 25.2 cu. ft....
Water in door quit working. Ice maker is fine
The water control valve on rear of refrigerator has two parts. One side for ice and the other side for dispenser. If I had your model number I could tell what to get. Ask questions or rate me, thanks, Sea Breeze
Dec 18, 2009 | GE Refrigerators
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser quit working on GE Profile French door 'frig.
The dispensers could be clogged with mineral deposits. If you look in your care manual it talks about a water vinegar solution that you pour into the top of the despenser, let sit, and then drain it through the back. I had a similar problem and it was because some of the water that was sitting in the top of the unit(where the gallon jug sits; under the black think) was full of frozen water which was blocking the water dispenser.
Apr 29, 2009 | Refrigerators
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice and water is not coming out. ge side by side
Check the plug to the door first. Then turn the ice machine head off unplug the refrigerator for a few minutes. Plug it in and turn on icemaker. this part problably just lead back to squre one. have someone push the button for water while you are listening at back bottom for humming sound,if you dont hear it its probably a bad water valve.
Mar 21, 2009 | GE Refrigerators
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
