Question about Maytag Dishwashers
Maytag dishwasher groaning during wash cycle - Maytag Dishwashers
SOURCE: Dishwasher
detergent dispenser solenoid
Posted on May 13, 2007
Buffalo12980
  • 625 Answers
SOURCE: re: Maytag dishwasher
does the timer advance the control knob? check to see that nothing is in the way of the center spray tower. does it sound like any water is spraying around inside?
Posted on Sep 01, 2007
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
SOURCE: Maytag dishwasher legacy 300 quiet series
I was so impressed with the advice on this website, I thought I would take a stab at this. The difference is, I will include all the steps, so if I go into a little too much detail for you, I'm sorry, but I felt a few things got left out that needed to be said.
Tools Needed: screwdriver with t-15, and t-20 torx bits (available at any hardware store), and a pair of pliers. Also I used a headlamp so I did'nt have to hold a flashlight with my teeth.
step#1- Clear a spot on your counter or kitchen table and remove both the lower and upper racks from your dishwasher. The lower rack just lifts out, the upper you will find two light blue plastic caps that once removed will allow you to slide the rack off of the metal slides. Next, the long L shaped spray bar that goes up the back and across the top needs to be un-clipped and removed, 2 clips at top and 2 clips at the back. It might take a little wiggling but that spray bar slides into the top cover, once unclipped push back at the bottom and tilt the upper part toward you, it should come out fairly easily and give you wide open access to the cover. Next you want to remove the plastic nut that holds the spinner in place, using your pliers turn it counter clockwise, it should loosen fairly easily, and remove nut and spinner. Next with either a T-20 or T-25 torx bit, remove the 3 screws that hold the outer cover in place, notice the direction of the tube that plugs into the spray bar, make sure it goes back in the same way. Now remove the T-15 screw that holds the black grinder cover in place and remove screw and cover. Now remove the 6 screws that hold the inner cover in place and remove the cover. You can now see what all the fuss was about, mine included a piece of pistachio shell, a bay leaf, and a cherry pit. Once it's all cleaned out, just reverse these steps and be ready! You have just earned your place as your homes resident handyman or woman!
Posted on Jun 14, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have the same groaning noise with my dish washer GSD2200G02WW
Remove both spray arms, and try a cycle with the washer empty.
If the noise changes or dissapears - replace one spray arm and try again. Replace the spray arm that creates the noise.
If there is no change, then replace the drain pump.
May 02, 2010 | Dishwashers
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
My maytag won't spin. The agitator moves but the
Sounds like the transmission is shot. Call a repair shop, or buy a new one.
Oct 21, 2009 | Maytag Performa PAV2200
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Dishwasher soap cup lid will not open during a wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
jj
Dec 31, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag dishwasher shuts off during cycles
thats what it soundslike to me here aoart number which is the entire assy w/both switches included 99002254 retails for about $25
Nov 05, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Feb 15, 2007 | Maytag 24 in. MDBH940AWS Built-in...
Dishwashers Logo
21 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
