Question about Kenmore Sewing Machines
How to install super high bar walking foot DP6888
Received super high bar walking foot DP6888 with directions directions are not clear for Kenmore convertible sewing maching model 1680
SOURCE: Kenmore sewing maching model 158.904
I bought mine at Walmrt. They are a Singer product and says it will fit most machines. There are 2 belts in the package and the small one is for bobbin winders. I have a Kenmore 158,904 and it fits perfect.
Posted on Jan 21, 2009
  • 69 Answers
SOURCE: Kenmore Sewing maching 158 15510: sewing mechanism
You put the hook (the half moon thing with a sharp point on it) in the machine by placing it opposite the little curved bar. Make sure it is seated properly on the ridge. The you take the race, the circular part with a small plate on the top and place that over the hook(the plate side will be facing up). It will only fit a certain way, it could have a slot that a notch fits into (that is usually how it goes). Then slide the arms over it and they will snap into place. Once done, turn the handwheel and make sure everything moves smoothly. If not, you'll need to start over as something isn't seated correctly. Then you can install the bobbin case as usual.
Posted on Mar 01, 2009
SewCreative
  • 15 Answers
SOURCE: sewing machine maintenance, walking foot & free-motion foot
Is this a Janome MemoryCraft 9000? (I ask because the models seem to get mixed up in the threads)
If so, you can more than likely find accessories for the MC9000 either on eBay, your local Janome dealer (you can find the closest one to you @ Janome's website using the "Dealer Locator" feature) or even ... SEARS!
Sears contracted Janome to make several of their sewing machines (I think Janome might still be the actual manufacturer, but aren't 100% sure) and so the parts are compatible. You can even use a Kenmore Memory Card with a Janome MC9000.
As for oiling, if it's the MC9000 (much like practically all newer models) they don't need oiling. Though sometimes, you can dab a teeny-tiny amount of oil on the bobbin case if it needs it.
Posted on Apr 15, 2009
wfservices
  • 260 Answers
SOURCE: Need instructions for putting a walking foot together
http://www.husqvarnaviking.com/us/2821_3079.htm
This is a link to husqvarna site for help..Hope this can help you. Wayne
Posted on Mar 21, 2010
What is a walking foot and what does it look like,please
There is a "fork" or straight bar on the needle-screw side of the foot that wraps around or sets on top of the needle screw. This fork/bar moves with the needle and causes the foot to pull fabric through the top, much like the feed dogs underneath.
Be sure you get a walking foot that will work on your machine!
When installing the foot, it helps to raise the presser foot bar as far up as it will go and that the foot is tilted slightly to slip in on. If you have a knee-lift bar, using it to lift the presser bar will sometimes give you just what you need to get it on. Do NOT bend the walking foot to put it on.
How to Use Walking Foot Attachment Sewing Machine
Problems installing my walking foot
Oct 23, 2016 | Sewing Machines
How do I attach the quilting bar to the walking foot on my Simplicity Quilters Classic? The manual doesn't show how to do it
There should be a hole across the back of the walking foot (penetrates the walking foot usually from right to left, although some feet will have 2 guides--one for left to right, the other left to right) where the bar mounts and a screw to tighten and hold it in place.
Quilting Bar Attachment
Oct 06, 2016 | Simplicity Quilter's Classic SW240...
Brother sewing machine LX 2500
Walking feet attach much the same way on most machines. They can be boogers the first couple of times. It helps to tilt the foot and guide it toward the needlebar from the side in order to get the fork (if your foot has a fork--some just have a bar that sets on top of the needleclamp screw) around the needleclamp screw. In cases of extreme frustration, I've removed the needleclamp screw and then reattached it once the foot is in place.
Just use patience. If frustrated, walk away. Whatever, do not force or bend the foot in order to install.
How do attach the walking foot Brother
How to use the Brother SA140 and SA188 Even Feed Walking Foot
How to Use the Brother SA107 Walking Foot
Attaching Walking Foot
How to attach walking foot to your sewing machine Elizabeth Ruffing Art...
Jun 07, 2016 | Brother Sewing Machines
Cant get the bernina walking foot in position on the 1031 machine
The walking foot has a spring loaded lever that rides on the needle clamp screw. If you lower the needle into the hole on the walking foot it will remove the pressure and make it easier to attach the walking foot to the ankle.
Mar 07, 2016 | Bernina Sewing Machines
Why doesn't walking mechanism work?
if the pressor foot anvil doesn't move up and down /back/forth , the machine might be in "DARNING " mode this is usually a small button in the bobbin area , but some machines have them on the back of cabinet as well
Feb 26, 2016 | Sewing Machines
Old Bernina 830 walking foot not pulling item through.Lever not letting foot down completely but can push it down the rest of the way with my fingers
Hi Linda:
Does your 830 have a black needle clamp and screw instead of the standard nickel plated clamp? If not, the walking foot forked driving lever may be damaged by having used the machine with zigzag engaged. Another problem with older 830 machines is that the needle clamp has been repeatedly tightened very tight, causing the needle bar base to become damaged so that the clamp is no longer perpendicular to the direction of sewing...In other words, the clamp sets crooked on the needle bar.
The black clamp made for the walking foot had a specific diameter for the forked driving lever of the walking foot. The black clamp was also longer so that when using a wide stitch width, the driving fork of the walking foot did not collide with the needle bar clamp screw on the right side.
Please reply with your observations.
Oct 29, 2015 | Bernina Sewing Machines
I have a Kenmore model 158.19411 and I want a walking foot for this model. Is this model a high shank or low shank?
The Kenmore 158.19411 uses super high shank presser feet. Sears Parts Direct has the zipper foot still available for the 158.19411. http://www.searspartsdirect.com/kenmore-sewing-machine-parts/6759/0020/158/model-15819411/0582/1220000.html . Other compatible feet are available here: http://www.sewingpartsonline.com/kenmore-158-18023-sewing-machine-parts.aspx . This site also has an adapter for connecting Kenmore-compatible low shank presser feet to the Kenmore 158.19411 .
I hope this helps.
Aug 23, 2015 | Kenmore Sewing Machines
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Mar 24, 2011 | Elna 8007
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
How do I attach a walking foot
Okay let's get started.
  • First let's look at the walking foot.
  • Turn the bulky body so that it's away from you.
  • On the left you see a groove that is going to be where you attach the foot to your machine.
  • On the right is a u-shaped arm which you can move up and down. It will go over the needle clamp
Now, let's remove your present foot from the machine and look at it.
  • Loosen the foot screw until it almost comes off. (if it does come off, screw it back on a bit.) The screw is on the left of the foot-bar.
  • On the right you'll see the needle bar with a needle clamp (what you tighten when you replace a needle) on the right of the needle-bar.
Okay the walking foot business.
  • slide the walking foot into position so that the foot screw is in the slot on the right and the u-shaped arm is over the needle clamp, with the needle clamp in the middle of the u-shaped opening.
  • Tighten the foot screw securely, it's going to be under more strain than normal.
  • While you're at it, check that the needle-clamp is nice and tight as well.
Okay, then! There you go... Happy sewing.
Are you happy? Than please vote
Here are a few helpful pictures.
Feb 01, 2008 | Singer 7436 - INGENUITY
Sewing Machines Logo
47 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
