Acer monitor h233h cycling colors - Computers & Internet
goththug
  • 10 Answers
SOURCE: Brand New ACER H233h Monitor
Have you checked through the setup controls on the flat panel. I've seen a few that had the audio turned off by default. That is sometimes done because it generates static noice if there is no audio sourced coming through them.
Posted on Aug 26, 2009
  • 35 Answers
SOURCE: installing Acer H233H monitor to a Dell XPS630
Check continuity of cable with ohmmeter, if ok try different monitor to make sure signal is being output by computer.
Posted on Oct 09, 2009
benwabnick
  • 2404 Answers
SOURCE: acer h233h monitor flickers with any cpu usage
Try another known working monitor to see if the same thing happens. If so then that means the video card or onboard video on the motherboard is bad which means the motherboard is bad.
If the problem gets resolved then that means the original monitor is bad.
Posted on Jan 04, 2010
pravinbhavsa
  • 348 Answers
SOURCE: trying to use an acer H233H lcd monitor with a Dell 4600
you have to install the original video drivers into it .from www.drivers.com if you have original drivers then install an AGP card into an AGP slot then you can see higher resolution
Posted on Apr 08, 2010
budmrtn
  • 11361 Answers
SOURCE: how to open the case
After removing the base and all the screws, I use thin flat blade screw driver to separate the front and the back of the monitor at the bottom edge and work your way around, not much you can do without scratching the case since it uses a lot of thin plastic fingers to hold the monitor together like a hook which snap together real easy but hard to separate.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 23, 2011
H233H monitor bad video
maybe some component in monitor is broken
go to service monitor station to chek it out
Dec 21, 2013 | Acer H233H 23 inch LCD Monitor
I recently bought the H233H monitor to use on my new Win7 PC. When I am viewing anywhere online all the background stuff shows up pink. Replies on Facebook are boxed in pink as well even though every other...
So, your "new" monitor is the only monitor with the problem ?
Exercise the WARRANTY for the Acer monitor, and get it replaced/repaired, at no cost to you.
Sep 29, 2010 | Acer H233H bmid Monitor
Acer model h233h has blurry horizontal lines periodically up and down the screen
Try to reposition the video / VGA cable....Its EMI interference
Jul 28, 2010 | Acer H233H bmid Monitor
I am running Red Hat Linux Enterprise my new Acer H233H is saying Input not supported any help would be greatly appreciated. Thank you
It says input not support because the PC video resolution is too high for the monitor to display, just need to lower the resolution. Nothing to do with OS, just the video setting.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.productwiki.com/acer-h233h/
If you set to native resolution and it still does not work then you will have to open it up and inspect the inside.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 31, 2010 | Acer H233H bmid Monitor
My monitor has a yellow line running down the middle
This is a bad LCD panel. If it is still under warranty, your best bet is to have it replaced again. The only fix is to replace the actual panel and that would cost more than a new monitor.
Sep 28, 2009 | Acer H233H bmid Monitor
Aug 26, 2009 | Acer H233H bmid Monitor
Blank Space Around Screen
Reduce the resolution a little.
Sep 20, 2017 | Acer H233H bmid Monitor
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
