Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave shuts off after running for five minutes
I have a ge xl1800 over the range mircowave, model number JVM1851sh06. My problem is that if my microwave is running for more than five minutes at a time it shuts off. After about 10 minutes it turns back on again and I have to program the clock etc. The light and the turntable do not turn on anymore either. It all started when my wife saw a spark between the bottom of the door and the control panel. Is this a blown fuse? Any help is greatly appreciated. Thanks
  • GE Master
  • 1,830 Answers
I'd be careful because you do not know what caused it to spark. How old is the microwave? Do you need a new one?
Posted on Jun 14, 2017
SOURCE: Repairing Microwave
check high volatage circuit, and magnetron, and wiring and control unit or circuit...
Posted on Oct 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: My ge profile spacemaker xl1800 turntable stopped .
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
rickzilla
  • 706 Answers
SOURCE: GE XL1800 (JVM1851SH06) Smoke
It all depends on what is generating that smoke..Where there is smoke. there is cost associated with it.. By virtue of diagnostic time or component replacement or both..If your micro is a potential fire hazard then don't compromise your safety. If your warranty JUST expired, you might be able to convince the service people at the place you bought it that it is defective.. and they just MIGHT surprise you by replacing it free. Why not take a shot at it? In fact, if they try to adhere to the letter of the date. then get LOUDER and LOUDER in front oif as many customers that you can.. In some cases, you might be better off talking directly with the dept manager insead of the normal service reps.. Good Luck.. Be Safe...
Posted on Oct 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Mircowave will not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Eterna Microwave stops after a few seconds, must reset clock..
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, this is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
(PLEASE do not be fooled into thinking that the procedure outlined at this link is a "fix". It should only be regarded as another test method to prove that you have a noisy magnetron which must be replaced.)
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
If it keeps failing while the board is in the down position, you either have a very leaky magnetron or possibly another problem.
So you can then get a Ziploc bag and insert a flat piece of aluminum foil into the Ziploc and close it.
Then (with the power off) tape it over the circuit board as best you can, covering it as much as you can, making sure it does not get snagged or punctured.
Then try the oven again. Do not leave this test shield in place as a "fix". It is not safe.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 25, 2009
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
JVM3670sk6 mircowave over the range, vent door continues to open and shut when oven is off
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing sensor switch in the vent fan / louver assembly or a damaged component.
There should be a technical sheet hidden behind the grille or behinds the controls. It's very handy to locate and test components.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes.
Apr 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. profile Spacemaker XL1800 over the range microwave. the microwave comes on but dose not make anything hot. what is the fix & where is the replacement part located ?
We would need the full model number and we would need a little more information.
Please repost here with that information, and let us know - when you press "Start" to cook - if the inside light, turntable, and internal cooling fan all come on.
Nov 28, 2012 | GE Microwave Ovens
GE Profile Spacemaker XL1800 Magnetron failed and replaced but now it heats too much for one touch sensor buttons...Basically the unit stopped heating. I replaced the Magnetron. I test by trying to pop...
You probably just have a bad humidity sensor (aka gas sensor).Also be sure the internal cooling fan is running. That's critical.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
To access and replace the sensor, you may need to remove the oven from the wall.
You can find handy exploded views and order parts by model number here.
Oct 21, 2011 | GE XL1800 1100 Watts Microwave Oven
I have a GE Spacemaker XL1800 Adora Microwave (manufactured in 2004) and the light bulb went out but I can't located it to replace it. Where is it located? Thanks
If it is meant to be user replaceable, then your owner's manual will cover it.
If not, then you may need to remove the oven from the wall.
Either way, you can download GE owner's manuals and installation instructions here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Jan 17, 2011 | GE XL1800 1100 Watts Microwave Oven
I have a GE microwave model JVM1851SH06 that is completly dead. I replaced the Fuse and power came back, but 30 sec in it was dead again. What should do next.
You need to first verify that your outlet is correct at 105 to 125 volts AC.
If so, then you may have a failing high voltage transformer (rare) or possibly a failing magnetron, etc.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
(if it is NOT shorted or burned looking, it's probably fine)
(continuity can be good even though mag is bad!)
May 26, 2010 | GE XL1800 1100 Watts Microwave Oven
Dec 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Mircowave JES2251SJ -
The internal magnetron cooling fan is located behind the control panel assembly.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Nov 29, 2008 | GE JVM2050 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
275 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
