Question about RCA Dolby Digital Decoder Home Theater System - Black RT2761HB
Sound cuts out after being turned on for a while
We hooked the RCA home theater system to the Direct TV box and DVD player and it seemed to work fine last night but this morning after about 4 hours of having the tv on the sound quit. I had to shut off the unit and turn it back on again and the sound was back but it cut off again in less than an hour. Is there a fix or is it just faulty?
SOURCE: Hooking up the RT 2600
I dont know ware or what to hook up and how
Posted on Jan 02, 2009
SOURCE: I have a new 52"
I have the same situation....what I have done is connected my Blue ray to the TV via the HDMI connection and the audio to the RTDVD1 via an Optical cable. I find this is the best connection and sound reproduction so far. The input of the RTDVD is the SAT/Optical input and then switch the source to SAT/OPT. You will have to make adjustments in the BlueRay player's audio setup to enable the 5.1 DB digital sound etc.
Posted on Feb 28, 2009
  • 899 Answers
SOURCE: when i unplug my rca rt2250 home theater system.
this is the amp IC and while unplugging and plugging it in again helps reset the IC for a little while , it will eventually completely quit and will need replaced
make sure that none of the speaker wires(bare wires) are touching or look like they might be where they are connected at
also if turning up the volume makes it cut out or sound bad then this will also indicate a bad amp IC
Posted on Mar 12, 2009
  • 151 Answers
SOURCE: Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
Posted on Apr 19, 2009
frederiquema
  • 76 Answers
SOURCE: I have an RCA Home Theater System Model Number
Make sure that ALL ur cable r well conected! Sometimes just by moving cables it makes a difference.
Posted on Sep 13, 2009
How do you get sound to come from tv out of speakers of home theatre system
It just depends on the tv you have. If you hook up the RCA jacks to the (Audio out) of the TV into one of the (AUX in) ports of the home Theatre system you should be able to geet the sound that comes from the TV to play out the theatre system. If you are watching through a cable box you will need to hook the RCA cables to the cable box (Audio out) too the theatre systems (AUX in), in insted.
Mar 05, 2011 | Televison & Video
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
RCA RTD215 Home theatre system
click here for the manual http://www.voxxsupport.com/images/manuals/RTD215/media/RTD215_UMEN.pdf
If you need the manual for the tv,just reply with make and model.
Please don't forget to rate this as a fixya
Feb 01, 2009 | Audio Players & Recorders
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
No sound
Maybe the audio amplifiers ICs are damaged.
May 21, 2008 | RCA RT2600 System
RCA Dolby Digital Decoder Home Theater System - Black RT2761HB Logo
41 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
