New hard drive on iBook g4
Hard drive gone
  • 706 Answers
It is not an easy job to change a HD on an old iBook G4.
you need some experience in handling microelectronics.
step-by-step guide is available here:
https://www.ifixit.com/Guide/iBook+G4+14-Inch+933+MHz-1.33+GHz+Hard+Drive+Replacement/189
iBook G4 14 933 MHz 1 33 GHz Hard Drive Replacement New hard drive on iBook g4 - 24100867-eger5opjetenbdaollq52u3v-5-0.jpg
Posted on Nov 20, 2014
Joed911
  • 4338 Answers
SOURCE: IBOOK G4
You may have a RAM problem.One of the most serious problems that can afflict your Mac is "bad memory" -- the common term for a defective RAM chip.
Apple provides Apple Hardware Test with every new Mac -- it's either on the Mac OS X Install/Restore disc, or on a separate Hardware Test disc.
Here are the instruction on how to run the Apple Hardware Test CD:
http://support.apple.com/kb/TA25668?viewlocale=en_US
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 16, 2008
  • 8 Answers
SOURCE: My ibook G4 was freezing on airport earlier this
This is a very open question, which can be open to many interpretations. but if you are concerned that your HD is a goner, the easiest way to find out is by listening to your drive's "noises." If you hear that the drive is make "repetitive" noises as if it almost sounds that it's "stuck" trying to read something. Then, it will most likely be your HD. There is software that can read your HD and tell you how the partitions and physical health of your HD are doing. But if you are no wiz at this, then "noises" may be your best guide. Since, you will most likely notice that your HD isn't making its usual "noise.s" The other side of the coin is... have you been messing with your mac's language? did you install something that you didn't even know what it was? (but you did anyways) did you accidently click on something, that was actually important? or is there something on your dvd/cd slot? sometimes if you leave a cd/dvd in the slot it may prevent mac from starting properly or just slowing the start up to a crawl. I'm not so sure about this one, but Apple recently released an update for airport. try to install it, but then again if you can't even start up... If i was on your position, and I kept a good track of what I do with my computer, and I knew it was a couple of years old.... I would consider replacing the hard drive. HDs will last a couple of years, but since they have moveable parts.. they have to break at some point.
So there, those are pretty much all the possibilities that you should consider. Hope that helps and good luck
PS that's why is important to always BACK UP your data :-)
Posted on Apr 21, 2009
  • 17 Answers
SOURCE: ibook g4 screen issue
That screen will most likely be compatible - I work on these for a living. The G3 laptop screens are usually not compatible with the G4 laptops, but all G4 laptop screens are compatible with eachother (provided they are the same size, of course.
Posted on Nov 13, 2009
exprich
  • 79 Answers
SOURCE: Extracting hard drive data from inoperable iBook G4 Apple laptop
well there is a solution so first check the type of hard drive in your ibook and check if any of your friends have an ibook, if so replace hard drive with yours and you can extract your data if your hard drive is working.
good luck.
Posted on Jan 05, 2010
APPLESUPPORT
  • 70 Answers
SOURCE: i have an ibook G4. The display is hard to read
Try reseting the PMU and Pram,also check the d.Also check the system with saperate OS installed HDd.It will work fine.Format the HDD and the issue gets solved
Posted on Apr 20, 2010
Ibook g4 won't open just gets a flashing equation mark and the finder icon
Sorry, either your hard drive cable is loose or your hard drive has died.
Mar 10, 2013 | Computers & Internet
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Repla the hard drive
Need to open the HDD cover which is in the bottom of your Ibook. But it requires special elen key to open the cover.
Revert back for more assistance.
Feb 03, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
good luck.
Jan 05, 2010 | Apple iBook G4 Mac Notebook
My ibook wont start up i power it up and blank screen and making a bit loud noise while its on...is there anyway i can bypass this and get to my start up menu?
"Loud noise" implies either the fans, the hard drive, or the optical drive, as those are all the moving parts in an iBook. If it won't start up, I'm guessing you have a bad hard drive. If so, you can revive your machine with a new hard drive, but your old files are probably toast unless you have backups.
Oct 03, 2009 | Apple iBook G4 Mac Notebook
Ibook g4 freez
Freezing is a HD problem. Do you hear clicking sometimes? Sometimes on boot up is there a foler with a questionmark in it? I would get your hard drive looked at, this is the reason disc utility fails. Your hard drive has a hiccup.
Jun 19, 2008 | Apple iBook G4 Mac Notebook
Apple iBook Mac g4 Notebook hd doesn't appear
You have a hard drive issue, this is why it freezes. DO you hear clicking sometimes in the laptop? I would get your hard drive looked at by a tech.
Jun 09, 2008 | Apple iBook Mac Notebook
Stop working ibook g4
http://coreyarnold.org/ibook/?p=20
May 11, 2008 | Apple iBook G4 Mac Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
