Question about KitchenAid 32 in. KECC502 Electric Cooktop
What are the cut out dimensions for KECC502 G
I have a Jenn air c221 cooktop in need of replacement what are the dimensions of this unit.
Here are the dimensions for the Jenn air c221 cooktop. Hoping this will help.
width 29 15/16th of an inch.
depth 21 9/16th of an inch.
cutout width is 28 7/8th of an inch.
cutout depth is 20 15/16th of an inch.
Feb 04, 2011 | Cooktops
What are the dimensions for the JED8430??
The top dimensions are 29 3/4" x 22" and the cut out needs to be 28 7/8" x 21 1/8" if the need the install manual you can get on the link below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8101P419-60.pdf
Good Luck and please Rate 4 thumbs for the free answer
Jun 06, 2010 | Jenn-Air JED8430 Electric Cooktop
Kitchenaid KECC502 Electric Cooktop: LED light at the left rear knob is always on but the left rear burner single or dual does not work. I tried to turn knob on and off but nothing enable burner.
I wish I had the exact answer, because I have the same exact problem!!! You posted this about a month ago, which is when my unit started having LED "on" problems. Just in the past week, the top left power on LED will not go off, and nothing I can do gets the dual large burner to come on. Any thoughts??? Reply to: mchunko@csonka.com
Mar 25, 2010 | KitchenAid 32 in. KECC502 Electric Cooktop
One of the dials (the pot) doesn't work anymore. How easy is it to replace for a DIY?
it's called a rheostat -no it is not hard to replace ---open the breaker, of course. write down the wiring if you think necessary---then remove and replace. you might want to check/compare the rheostat to one of the others to verify it as the problem
Jun 26, 2009 | KitchenAid 32 in. KECC502 Electric Cooktop
I just need to know the cutout dimensions for jenn air smoothtop
i asume that you want to cut your counter to drop the hot plate in turn your plate upside down measure about 1inch smaller than the dimention of the plate is should work fine thanks from gilles
Mar 15, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
ELEMENT WONT SHUT OFF
Sounds like that specific element has shorted to ground inside it's sheath. You'll probably find the element does not get as hot as it normally would.
A fuse will not blow, or breaker not throw, because of the point in the element that the element has grounded.
Elements are available from a number of resources.
A way to test if the element is shorted to ground:
Tools needed -
Ohmeter
1)Disconnect power from the appliance
2) Remove the element (Sometimes they are plugged in, sometimes the wires screw onto the ends of the element.
3) Set the Ohmeter to Rx1000 or more.
4) Measure the resistance between the outside metal sheath, and either of the two power connection points on either end of the element. Under any condition, you should not get a reading. If you do, the element is bad, and you need to get a new one. They are not repairable.
5) Re-install in the reverse removed.
6) Check all connections are clean and all is re-assembled as you originally found it.
7) Turn on power and check if element comes on.
It is unlikely the problem is with the control, but it is a possibility. Give me more info about the cook-top (make, model) so I can investigate further.
Jan 14, 2009 | KitchenAid 32 in. KECC502 Electric Cooktop
Thermadore Stove Top Ignitors Won't Stop Clicking in the OFF POSITION
Needs to be serviced. The electronics for the igniter section has gone bad.
Sep 03, 2008 | KitchenAid 32 in. KECC502 Electric Cooktop
KitchenAid 32 in. KECC502 Electric Cooktop Logo
106 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
freddyfox
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
