Question about Krups 203-42 Electric Blades Grinder
How to open base - Krups 203-42 Electric Blades Grinder
Do I Need To Have A Business License To Open A Home-Based Business?
Sure, you will need a business license to open a home-based business. You need to contact the business licensing department of your municipality and find out what the necessities are.
Apr 11, 2016 | Retail Supplies
How change front fender f150 2000
Fender -Front Removal
  1. Remove the radiator grille opening panel reinforcement (8A284).
  1. If equipped, remove the front wheel opening moulding.
    1. Remove the pin-type retainer.
    1. Remove the screws.
    1. Remove the wheel opening moulding.
  1. Remove the front fender splash shield (16103).
    1. Remove the pin-type retainers.
    1. Remove the front fender splash shield.
  1. Remove the cowl grille.
  1. On RH front fender, remove the antenna mast.
  1. On RH front fender, remove the antenna base.
    1. Remove the radio antenna base cap (18A927) by gently inserting a thin straight-edged screwdriver underneath the cap and carefully following inside the perimeter until both snaps are free.
    1. Lift the antenna base.
    1. Disconnect the radio antenna lead-in cable (18812) and remove the antenna base.
  1. Remove the fender stuffer.
  1. Remove the stone guard.
  1. Remove the front fender.
    • Remove the bolts.
Sep 17, 2014 | 2000 Ford F150 Flareside SuperCab
Why does line in use stay on so I can't use my phones ?
It is the base station keeping the line open. So nothing other than pressing disconnect on the handset that opened the line in the first place, won't close the line.
You could try to disconnect the power from the base station. thats should at least make free the line. I hope when you replug the base station, the line will be free again. If not I'm afraid you have to use another base station, or give it in repair.
Jun 14, 2014 | Lands Phones
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
No link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
Feb 23, 2010 | Lands Phones
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
The base of the clear bin won't open.
Just had the same problem. Finally realised what to do. Pull the long rod away from the top against its spring (by the rubber gaiter) and whilst holding it, undo the screw holding the long rod to the top trigger mechanism. Now you can wiggle the rod part free (careful of the plastic lug on the side opposite the screw). Now, you can look down through the cyclone whilst inserting the rod properly into the releaser at the bottom and open the base. Reassemble the rod into the top. NOW reinsert it into the cyclone with the base door OPEN and using two fingers locate the rod into the releaser lever. Now you can close the door. Phew. Hope this is clear enough as a guide.
Jan 28, 2009 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Travel cot by chicco
the secret to open that chicco travel cot is to make sure while opening the upper clips make sure the base is still closed. its a safety thing. then open the base.
Jul 16, 2008 | Baby Gear
Opening the Woofer
Pete C - I had the same issue, and the same frustration.
The key is-> the floor bumper on the back side has a hiden screw under it. Remove the bumper, then stick a hook in the hole to pull out the plastic plug, then the screw is accessable. Good luck on finding anything inside.
Jul 30, 2007 | Harman Kardon HK695 Computer Speakers
Krups 203-42 Electric Blades Grinder Logo
118 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
