Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Bissell rotating brush won't spin
How to disassemble and clean so it will spin again
reddevil6
  • 1673 Answers
SOURCE: Brush is not rotating.
Turn the vac over, remove the access plate, covering the brush roll, 2 to 4 screws. Brush roll part number is 2032032if you need it, belt is a Bissell Style 7. While you have the brush roll off, check in dirt inlet to see if it is clogged, also check the hose to see if it is clogged. You won't feel suction at the bag tube, it has to have a bag on it and the lid closed before it will create suction.
Posted on Jan 09, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Posted on Jan 22, 2008
SOURCE: Bissell steam carpet cleaner
http://www.howtomendit.com/answers.php?id=76173
Posted on Sep 28, 2008
  • 5 Answers
SOURCE: Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Posted on Dec 14, 2008
  • 29 Answers
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Posted on May 29, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell 6591 operating twice as loud as before.
Hey Mike! Excessive noise can be contributed to dirty filters or clogs. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Feb 03, 2013 | Bissell 6591 Power Trak Revolution Bagless...
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
I have a Bissell vacuum #6594-W. The brush bar will not spin. It keeps melting the belt on the other end of the pully...HELP!
Remove the beater bar and spend some time removing the hairs and carpet fibers from the roller. It may take some cutting with a sharp knife to get it all, but with patience, you will have it smoothly rotating again. Test it by holding it just by the metal end and rotating the brush tube by hand. When it spins freely, it's ready to reinstall.
Dec 30, 2010 | Bissell Vacuums
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
Bissell carpet cleaner brushes won't turn
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
80 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
