I bought a 300 watt amp and 10in type s sub. i wired up the sub bridged on Chanel 3 and 4 like the directions told me and had a cross over foe the duel voice coil. it was fine for about a month then it started to bottom out when cranked up then it got to the point the if i tried to crank it up no sound would come out of the whole system. so for some reason i unplugged the crossover on the sub and it worked fine but still bottomed out when up high but didn't cut out. what could be wrong. thanks
  • 757 Answers
You are reaching the physical limit of the drivers' range of excursion. It is also likely that at least one of the voice coils has thermal protection and when you disconnected the crossover you also disabled that protection...thus no "cut out."
As for "bottoming out" you could either reduce the volume, or modify the subwoofer enclosure so it will reduce the amount of the cone movement.
Posted on Jun 18, 2009
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
What is the best way to wire four 6" 55 watt
My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
dreamsystems.
Feb 10, 2011 | Clarion APX490M Car Amp
I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
No knowledge of how to hook two subs which are the 12 alumni audiobahn sub to a performance technique 781 mono block amp operation ohms for the speakers say 3 or 12 ohms during operation can i bridge or do...
yor subs have dual 6 ohm voice coils from the sound of it-your amp is rated at 650 watts rms at a 1ohm load. The best you can do with the equipment you have is to wire ALL the coils of your subs in parallel and that will give you a 1.5 ohm load for the amp.It should knock the hell outta them with 300 watts on each sub - good luck
Jan 14, 2010 | Performance Teknique ICBM-782 Car Audio...
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
How to wire a sony 1200 watt amp
I believe what your trying to do is to run 2 12" subs and some other satillite speakers? We used to do that all the time.. That is called running the amp in "mixed mono" that's where the mids & tweets are run in stereo while the subs are bridged mono. This configuration is what made Rockford Fosgate "The Bomb" back in the day. To do what you want your subs have got to be 8 ohms, NOT 4, Dual Voice Coil 4 ohms would be OK. Before i tell you how it can be done let me tell you what will happen... For one thing you will be "making" your own cross overs for the subs and mids and tweets. Forget about using the cross overs on the amp. 2ndly you will lose about 1/3 to 1/2 of the amps power because the crossovers are so inefficient, so don't even think your going to get anywhere near 1200 watts from the amp. More like 300, and that's on a good day. But if you still want to do it you go to your Radio Shack and get 1ea 6.0 mHy (milhenry) coil and two 47 mfd (microfared) capacitors, or something close to that value. So you would wire your mids & tweets normal in stereo and on the + line to each mid wire in the 47 mfd capacitor. That is your h/p crossover which will crossover your mids @ appx 130hz. Now on your subs. You want to wire them in parellel (both +s twisted together and both -s twisted together so it looks like there is just one woofer with a + and a -) Than from the L+ of the amp run a wire to the coil and from the coil to the + of the woofers, than using the R- of the amp to the -s of the woofers. Do not use any of the amps built in crossovers leave it on full. Good luck. Mark @ Sounds Good to Me Tempe, AZ
Aug 25, 2009 | Car Audio & Video
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
How do i bridge 3 subs to a 4 channel amp
My information shows the XM-1652Z as being a 2-channel amp. It will not be stable below 4-ohms in bridged mode. For best power, your subs will need to be 2-ohms with all 3 wired in series. This will present a 6-ohm load to the amp. After wiring the subs in series, connect the positive speaker wire to one channel (+) and the negative speaker wire to the other channel (-). For the 1652Z no other wiring is necessary. For subs you will also want to set the LPF (80Hz) switch to the "ON" position (to the right).
Keep in mind that the rated output is only 400 watts RMS at 4-ohms in bridged mode. That's kinda wimpy for 3 subs. You would probably obtain better results from two 2-ohm subs, each connected to a separate channel. That way each sub would be getting 200 watts RMS, still low but there's lots of good subs that will sound pretty loud with 150-200 watts
Mar 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
21 people viewed this question
 Grubhead
Grubhead
