Question about Globe Bantam Beach Glass 24" Plastic Skateboard Complete - lime/raw/light blue 24in
Globe Bantam Retro Ripper Deck - 6.5x24 Horizon Blue
Just fitted a new clutch to a D1 bantam, put it in gear and the bike just sits there, with the clutchlever pulled in or released. All parts are new and assembled correctly even the ball bearing,
Hi, Phill the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to change Classic Motorcycle Clutch BSA Bantam DKW CZ MZ
Bsa Bantam D14 4 Clutch
BSA D14 4 BANTAM SUPREME D14 4 BANTAM SPORTS Workshop Manual
Motorcycle Parts for BSA D1 Bantam eBay
BSA Bantam Resources
BSA D1 125 Bantam Instruction Manual
Sep 02, 2017 | Motorcycles
My Horizon CT 7.0 treadmill slows down when i step on it
LUBE THE deck belt and rollers bearing . This happen because you must lube about 150 miles aprox. See the video and fix it. However if the problem persist. Time to replace the old board deck.
God bless you
Jan 25, 2013 | Horizon CT7.0 Motor Control Board
Sqeaking sound coming from horizon treadmill
Dear Sir:
Please LUBE the deck belt inmediately, the lack of maintenance is possible the deck is worn.
2) Test the drive belt 3) The roller bearing LUbe 4) Test the motor bearing.
all this parts is subject to maintenance, see your instruction manual.
RUN the software calibraltion for diagnose, and troubleshooting.
sincerely. God bless you
May 03, 2012 | Horizon Exercise & Fitness
Treadmill
Dear Sir:
PLease LUBE the deck belt, is possible the deck is worn!
2) Test the drive belt too 3) Test and lube the roller bearing 4) Lube the bearing main motor. All this parts is subjects to maintenance, see your instruction manual.
Run the software calibration for diagnose, and troubleshooting.
May 03, 2012 | Horizon Fitness Horizon T101 9 Program...
My horizon treadmill belt has started breaking from the edges. How do I repair it
Horizon Fitness sells replacement belts. There is no good way to repair a walking belt as they are a bit special, made to glide across a waxed or oiled deck.
Oct 24, 2010 | Exercise & Fitness
Treadmill says to lube belt, but we aren't sure where that would be?
Horizon treadmills need a silicon lubricant, placed between the underside of the walking belt and the deck board that it slides across. This should be done about once a year ;o)
Oct 23, 2010 | Horizon Exercise & Fitness
Horizon treadmill loud squeaking sound once I run over 3.0 (speed)
you need to lubricate the pivot points and deck. Check to make sure the deck is not broken.
Aug 04, 2010 | Horizon Exercise & Fitness
Display says LUBE
It is time to lubricate the running belt you may purchase this lubricant at your fitness specialty store or directly for Horizon their # is 1-800-244-4192. Here is a procedure you can follow and your owners manual should have the reset procedure after completing lubrication procedure, if not while ordering the lubricant ask Horizon for it.
LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes.
Mar 13, 2010 | Horizon Exercise & Fitness
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Globe Bantam Beach Glass 24" Plastic Skateboard Complete - lime/raw/light blue 24in Logo
259 people viewed this question
Top Globe Sport & Outdoor - Others Experts
Are you a Globe Sport and Outdoor - Other Expert? Answer questions, earn points and help others
