Question about Samsung L100 Digital Camera
MY sAMSUNG l1OO
I have not had this camera for a year yet and i don't unerstand why it's acting up. I take good care of it and keep it in my case when im not using it...I don't understand. anywho... when i turn my cam on the lens go out and then right back in and the camera makes a beeping sound (beep beep beep). However I can view the pics I took from the previous day and also upload them to my computer, but I my cam is not charging up and I;m very concerned. please if anybody can suggest a solution I would be forever grateful to you, especially if it works.
Thanks
    Sergeant:
  • 321 Answers
Lens motion strip is broken call me +919890274954
Posted on Jun 18, 2009
How do I change the date on my camera?
Hello! Welcome to FixYa!
You can change the date of your
Samsung Digimax A503 Digital Camera. first of all turn your camera on. Now go to the menu by pressing "MENU" button. Now using right arrow key, Go to "Setup Menu". Now using down arrow key, select "Date". Here you can change the date that will be displayed on the captured images and set up the date type.
Here "Right arrow button" select the Year/Month/Day date type and "Left arrow button" is to move cursor to the Date Menu if the cursor is at the first item of the date and time setup.In all other cases cursor will be shifted to left of its current position and "Up and Down button" is to change the settings values. So you can change the date the according to desired format.
For clear picture the image of the menu where date menu is visible on the camera is given below
Don't hesitate to let me know if you want any further assistance.
I hope this solution helps you
Thank you and Keep using FixYa!
Sep 13, 2011 | Samsung Digimax A503 Digital Camera
Lens does not extend fully
If your camera is less than a year old, call Samsung for a warranty repair. If the camera is more than a year old you will need to replace the lens mechanism.
Some may tell you to blow compressed air into the camera or bang it on a table; these things will either do nothing or damage your camera even more.
Don't know your camera model, so I don't know if we can help with the repair as we aren't able to get every lens for every camera.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Samsung Cameras
Black spots and lines suddenly appeared on my samsung tl240 screen
I am having the same problem. Just called Samsung tech support and they say it requires service, so you'll have to send your camera to them to get fixed.
This camera is less than a year old. Not a good sign. I took a chance buying a Samsung camera. Well, I don't think I'll be buying another one.
Apr 21, 2011 | Samsung TL240 Digital Camera
The camera accidentally got changed to spanish, I do not unerstand spanish and nw I cannot change thesettings or anyting help
try to get the symbols and reach toh the language folder...wherever you see english select it and your language will be changed to english
Mar 11, 2011 | Cameras
It always says remove the cassette and I dont unerstand the problem
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Nov 01, 2010 | Canon ZR830 Mini DV Digital Camcorder
Poor Pictures from Samsung S630 Camera
Hi there Iris,
I have had a good look at the manual and cannot see that you could have done anything to the settings to cause this problem. It may be that the CCD ( detector ) is faulty, in which case the camera should be repaired under warrantly. Suggest you contact Samsung and complain.
Cheers and good look.
C.
Nov 04, 2008 | Samsung Digimax S630 Digital Camera
Software
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Sep 18, 2007 | Samsung Digimax S730 Digital Camera
Digital camera care
Use these camera care tips: • Store everything together in a case for easy transport. Use a good padded case and strap. Not only do cases protect the camera but, as with most of HP's digital camera cases, they often have built-in pockets for batteries and memory cards. • Use lens caps to protect lenses when you're not using your camera. No exceptions. • Clean your camera and lenses often with a soft cloth. The autofocus, exposure, and viewfinder windows need to be clean for correct operation. Your camera likes weather that’s not too hot and not too cold. Weatherproof your camera with these ideas: • Let your camera case kick back under a light-colored towel when you're under the hot sun. • Keep your camera warm under your coat when it's chilly outside. • Bad weather and stormy seas can make for inspiring photographs. But if you don't take precautions, you'll have a wet digital camera with sand in every crevice. To protect your camera from water, cover it with a plastic bag. Just make a hole for the lens to poke through and secure it with a rubber band. Voil?: a little rain jacket!
Sep 08, 2005 | HP Photosmart 945 Digital Camera
Samsung L100 Digital Camera Logo
187 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
