Question about Shur Line Paint Edger - Pad Refill 2/CD 4-3/4"
Shurline edger pad will not stay in place - Shur Line Paint Edger - Pad Refill 2/CD 4-3/4"
On a 1997 Saab 900 S the rear brake pads have a pin through the pad from one side of the calapir to the other. Will these pins come out when the calpir is seperated from it's housing?
these pins are there to keep the pads in the calipers
they will have to be removed to replace the pads
if you undo the caliper mount bolts then the pins will stay in place to keep the pads in place when the caliper is off the disc.
Sep 08, 2015 | Saab Cars & Trucks
My edger won't stay running
carb needs cleaned
Mar 15, 2015 | Garden
Grass trimmer head keeps turning without power applied to throttle
On an Echo, this means that the clutch is staying engaged to the walls of the clutch drum. Either the clutch drum is loose and the clutch pads are catching it as it turns, or the idle on the engine is set too high and the centrifugal clutch is just opening enough to catch the drum and spin it. Check the clutch housing and your idle speed.
Jun 12, 2011 | Echo Garden
The brake pads fell off my stationary bike because the nuts fell off the bolts so we reattached bolt but don't know how to position the brake pads so they will stay on-i am recovering from knee surgery and...
The brake pads only need to be lined up with the braking surface to work. As far as keeping the bolts in place I would suggest a drop of loctite (blue) on the threads of the bolts to keep the nuts in place.
Nov 16, 2010 | Tunturi Cycling
Parts for Black & Decker 14" Grass Hog Xp Trimmer/Edger
Easily, the best place and discounted parts place for this Black and Decker trimmer is eReplacementParts.com
Oct 06, 2010 | Black & Decker 14" Grass Hog Xp...
My yard machine Edger 3.5 hp wont stay runing if i put ges in the air filter hole it runs for a few sec. if I put my hand completly over the hole on the air filter it will run on low idle but as soon as i...
remove the gas can carefully the pulsa primer carburetor sits on top. Once you remove the tank open the cap and pour out the gas. THen carefully unscrew the five screws holding the carb on. Carefully lift the carb up leaving the gasket in place and clean the small 4 chambered bowl with starter fliud. Replace all parts put gas in it, push the primer until you see gas squirt into carb then pull the handle.
Sep 03, 2010 | Yard Machines Red Edger
I have a Poulan 3312 Pro, the primer bulb opped off...how do I re-attach it?
You may have to get a new one that has more flexibility and will stay in place. External bulb assemblies snap in place and the ones on top of the carburetor of course have a metal retaining ring with 2 screws holding the primer bulb to the primer base.
Aug 25, 2010 | Poulan Garden
Primer bulb has hole, how do I change it? Edger will not stay running, need to change primer bulb.
look in owners manual for correct size then go to your local BIG orange (" Home") store or its BIG blue (lowest) competitor. they have all kind and sizes available .usually just 4 small screws hold it in place.
Good Luck.
Mar 28, 2010 | Yard Machines Red Edger
Weedeater want stay running
My guess is that your fuel lines and/or primer bulb has a crack or hole in them. Check these out and let me know the results. I can also recommend a great place to get these from if they are bad. Hope this helps.
Mar 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Cord stayes out motor not running
Take it back to place of purchace.
We get these all the time if its the cheap bent sharft with starter between shaft and motor. the easy start spring gets jammed and needs replacing.
Dec 26, 2008 | Garden
Shur Line Paint Edger - Pad Refill 2/CD 4-3/4" Logo
14 people viewed this question
Top Shur Line Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Shur Line Garden Expert? Answer questions, earn points and help others
