Question about Sony Cyber-Shot DSC-W5 Digital Camera
USB driver software
Computer windows 8 can't recognize
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Posted on Apr 16, 2014
The computer can not recognize drive (unknown USB device).
Method 1 - Unplug Computer So how did I finally fix the problem? Well, if you are lucky, it's a super simple solution! Try this method first and if it works, you'll have saved a lot of time.
Simply unplug your computer from the power supply. Yes that is it! Note that this does not mean just turning off your computer using the power button because most modern computers don't actually turn off completely and the motherboard will still get power. This is useful sometimes if you want to remotely wake up a computer, etc.
The motherboard is where all of hardware of the computer connects to, including the USB ports. Sometimes the motherboard needs to be "rebooted" because things can go wrong, i.e. all or some USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should hopefully be recognizing devices again.
So first turn off your computer using the Shut Down option in Windows or pressing the power button and then UNPLUG the PC from the wall outlet. Let it sit for several minutes and then plug it back in.
Method 2 - Update Device Driver If Windows is not able to recognize the device, you may also see in Device Manager that the device shows up as an "Unknown Device". You can get to Device Manager by clicking on Start and typing in devmgmt.msc or by going to Control Panel and clicking on Device Manager.
In that case, you should right-click on Unknown Device, click on Properties, then the Driver tab and then click Update Driver.
If this doesn't work, you can also try to download the driver for your device from the manufacturer's website. If the USB device is just a flash drive, then it's probably not a driver issue. However, if you are installing a USB printer, drawing pad, etc, then it might be worth downloading the driver for that specific device.
Method 3 - Restart & Disconnect USB Devices The next thing you can try is to disconnect all USB devices and then restart the machine. once you have restarted, try to connect the USB device that was causing the problem.
If that particular USB port doesn't recognize it, try another one. If the device is recognized by a different USB port, there could be a hardware problem with one of the USB ports. If no USB port recognizes the device, then keep reading because it's probably something else.
Method 4 - USB Root Hub Another thing you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties.
Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box. If you have more than one USB Root Hub listed, you need to repeat these steps for each one.
Click OK and then restart your computer. Try to reconnect the USB device and see if it is recognized. If not, go back to the power management tab for each one and check the box again. If it does recognize the device, then leave them unchecked.
Method 5 - Connect Directly to PC A friend of mine ran into this issue and the cause ended up being his USB hub. He only had three USB ports on his computer, so he bought a hub where he could connect an additional 8 USB devices.
I guess this proved too much for his computer and it just started sporadically not recognizing various devices. After removing the hub and connecting the device directly to the computer, it worked just fine.
We haven't really been able to find any other solution to this problem other than reducing the number of items connected to the hub. Actually, one other solution worked, but it meant having to buy a new USB hub with more power.
If you are having this problem with Windows 8 or Windows 8.1, then you might be in luck. Microsoft has released a fix for Windows 8 not detecting USB devices properly. Make sure to install this hotfix if running Windows 8.
Method 6 - USB Troubleshooter If nothing has worked so far, you can download the Windows USB Troubleshooter Fixit tool. It's a free tool that works with Windows XP, Vista and 7.
You can either have the troubleshooter fix the problems for you or select the fixes yourself. I would just let it fix them for you since the choices can sometimes be confusing and technical for the novice user.
Method 7 - Update Generic USB Hub If you are getting the Unknown Device error in Device Manager, you can also try one other thing. Open Device Manager and then expand Universal Serial Bus Controllers.
You should see at least one item called Generic USB Hub. On some computers, you might see two, three or more of these. Right-click on the first one and choose Update Driver Software.
When the update dialog pops up, choose Browse my computer for driver software.
Jul 10, 2015 | Transcend StoreJet 25 750GB USB Hard Drive
How we install Ricoh1600le scanner driver through USB in windows 8 64bit
Scanner driver gets installed in your computer, not through the USB port, unless you have software on a thumb drive. Typically, you will download the driver from Ricoh, and install it. Then the computer will recognize the scanner, and you're good to go.
May 10, 2015 | Office Equipment & Supplies
How do I transfer pictures from my Samsung Galaxy Tablet to my HP Windows 8 Desktop computer. Windows 8 does not recognize the device.
Music, movies, photos and more can be stored on the micro Secure Digital memory card on your Samsung Galaxy S phone. To get all those goodies on the microsSD card you need to transfer them from your computer. Connecting your Galaxy S to your computer is done with the USB cable that was included with the phone and doubles as the charging cable when plugged into the outlet adapter that also came with the phone.
Plug the large end of the micro USB cable into your computer and the small end into the USB port on the top of your Galaxy S phone. Wait for your computer to recognize the phone. If the phone is not getting recognized it could a driver problem. Click start control panel administration tools computer management device manager scroll through all of your devices or for Windows 7 click start right click on computer select properties in the left pane device manager scroll through all of your devices. If you see a yellow question / exclamation mark ? ! or a Red X you will need to update the drivers for this device right click select update driver/reinstall driver software Rather doing a driver hunt which can take hours. http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 This might take some time being a freeware driver solution Note: The Driver program will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. Press the "Power" button on the top right side of your phone, briefly. Unlock the phone by dragging the padlock icon to the top of the screen. Drag the notification pane down by touching the top of the screen and dragging your finger to the bottom. Touch the "USB Connected" notification and then press the "Mount" button. Your phone's microSD card will appear to your computer like an external drive. Click on the "Start" button on your computer and then click on "Computer." Double-click the drive icon that corresponds to your Galaxy S phone. This will open a folder that shows the contents of your phone's microSD card. You can copy files to and from the folder like you would any other folder on your computer. Click the "USB Device" icon in the task tray of your computer. Click "Eject USB Device." Wait until you're done transferring files before ejecting the phone from the computer. Unlock your phone and drag down the notification area. Tap the "USB Connected" notification and press "Disconnect." You can now safely unplug your phone. Hope this helps.
Dec 20, 2012 | HP Computers & Internet
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
Pny 2gb not recognized by windows vista
Try connecting it some other computers.
If it does not work at all, spend $8 to replace it.
If it does work, then it's either the "hardware" on your computer, or the Vista "software" (wrong/missing USB device-drivers).
Apr 20, 2011 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I have problem with my usb not recognized.
go to the website and locate where you can download drivers/software, once you have done that look for the specific area and download the driver, or you can go to device manager and make sure the driver is working properly
Jul 16, 2010 | Dell Inspiron 8200 Notebook
Alesis Multimix 8 USB won't be recognized
There are NO drivers to be installed for this device. Plug in the usb to the device, and the PC once the PC is running turn on the mixer. XP should inform you that a USB Audio Device has been found & installed. Any software you use for rec'ing will let you choose what sound device to use, select USB Audio Codec.
May 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Webcam
Follow these steps to re-install the driver for the webcam. You will need to be logged in as an Administrator or have an Administrator password ready.
1. Click the Windows Start button.
2. Click Control Panel, System and Maintenance and then Device Manager.
3. Right-click on Chicony USB 2.0 Camera and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver
4. Select Browse my computer for the driver software.
5. Select Let me pick from a list of device drivers on my computer.
6. Select USB Video Device from the list, and click Next.
7. If the message “Windows encountered a problem installing the driver software for your device” appears, click Close.
8. Restart Windows.
Sep 13, 2008 | HP Pavilion dv6000z Notebook
Laptop toshiba a300-15m webcam driver
8. Restart Windows.
The webcam should now work properly.
Jul 09, 2008 | Logitech 250 Headset
Sony Cyber-Shot DSC-W5 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
