Question about LG 32CS460
Lg 32cs460 replacement screen - LG 32CS460
2 Suggested Answers
gopakumarg43
  • 74473 Answers
SOURCE: how to repair a blacked out LG 32CS460-UC with serial number 210MXPH4K216
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Mar 18, 2015
How to repair a blacked out LG 32CS460-UC with serial number 210MXPH4K216
Mar 18, 2015 | LG Televison & Video
My LG 32CS460-UC will not turn on It has a red light flashing in the lower right corner
the psu has failed prob a CCFL fault as it flashes red
the low voltages like 5v is ok
get it serviced by a tv person i think its more too do with the lcd panel
Oct 07, 2014 | LG 32CS460 32" Class HD 720p LCD TV, 60Hz...
Will the 32cs460-za screen fit into the 32lg2100-za
A cracked screen cannot be repaired. It should be replaced. Contact the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 15, 2014 | LG Televison & Video
My lg 32CS460 is changing chanels and turning off alone
Most likely bad main board, but could be key pad on the side of the TV, Turn on TV the disconnect the keypad wire harness, if the TV stays on or doesn't change channels it is a bad key pad.
Mar 24, 2014 | LG 32CS460
LG 32cs460-us TV black screen red light blinks 3 times
I can give you some advice on the first thing you need to try. Unplug the tv for 10 minutes. Plug the tv back into the wall or power strip. Try powering on the tv. This may work or may not. It is important to try this before moving on to more complicated troubleshooting.
Jan 20, 2014 | LG 32CS460
LG TV Model 32CS460 black screen power light is red, then flashes if you push the tv button.
Have you checked the output voltages on your power supply. If they are good and depending on what type of set you have it could be the logic or t-con board. Your set is in stand by mode put there because the diagnostic circuits have deteted a problem some where in the circuits and will not let it power up fully to prevent damage to other circuits. Disconnect all leads from your power board and check out put voltages. Their value is stamped on the board next to each pin, if these check good move on to a logic board( if equipped) and them to the t-con board.. I am thinking you have problems on your power board. Capacitors are the least of things that can go out on that power board.
Gillight
Dec 07, 2013 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture, no sound
see the troubleshooting index:God bless you
No sound
1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
2. Check if the TV, DVD player and Amplifier are connected properly.
3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
Using an Integral 4GB flash drive in USB port, how do you switch between drives on the flash drive?
A flash drive is only one storage drive. It appears on the Removable Disk drive in the Computer file if it is plugged into a USB port. You can change and access different files on your flash drive if you click on Removable Disk in your Computer file.
Aug 06, 2013 | LG 32cs460 32" 720p Lcd Tv
LG 32CS460 Lost freeview after cable unplugged
Check the cable connectors and the connectors on the wall and TV to make sure the cat didn't break any of them. (It seems odd that a cat would be able to pull a coax connector loose - maybe antenna cables in the UK aren't threaded as they are in the U. S. A.).
Oct 19, 2017 | LG 32cs460 32" Inch Widescreen 720p 60hz...
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
LG 32CS460 Logo
27 people viewed this question
Computer Repairing
Computer Repairing
