Question about pangolin QuickShow Laser Light Show Computer Software: Enttec DMX USB PRO Device DMX Trigger
Program will not start because of wrong date on Laptop
Date and time wrong on start up
This indicates the BIOS battery is flat and therefore cannot store the correct date and time in the BIOS. You need to install a new BIOS battery and then go into the BIOS setup to set the Date & Time.
Nov 14, 2012 | Advent Clearance 5411 Laptop...
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
Win 7 - Start > Search type System Restore
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Auto removal of any program or file downloaded online by my pc and inability to remove previously installed program on my nec laptop
If you have trouble removing a program - click on control Panel - Add Remove Program and then click to highlight the program you want to delete then click Remove and follow the prompts.
If this does not work then you can Restore to a date prior to installing the unwanted program. To do this click on Start - All Programs - Accessories - System Tools - System Restore - Restore My computer to an earilier date - Next and select a date prior to the installation of the unwanted program.
May 16, 2011 | Computers & Internet
When I start my Lenovo T 60 it show check date and time after that it show Key picture,thank
You get this message if your Laptop (CMOS/configuration) Date is really outdated and wrong: check and change your Laptop Configuration setting for Date and Time. Also check your Windows Date/Time.
If the date/time you enter is not maintained properly, especially after you switch off the laptop, then you have a bad backup CMOS battery that needs to be replaced.
Hope it helps.
May 15, 2011 | Lenovo Thinkpad T60 Notebook
My dell M1530 laptop has startup problems. It
Hi i'm Rain.
Well The reason that it is taking so long to load Windows is its in bad need of cleaning . Also there are too many things starting up with windows. Every program you download will want to start when Windows star up unless you change that.
Now the reason that is not Keeping the date and time is because the DDO battery for the bios is going back. I can Walk you thru the Disk Clean up and Disk defrag . But I would not advise you to open up your laptop and try changing the DDO battery.
To do a Disk Clean up .
  1. Click Start.
  2. Click All Programs.
  3. Click Accessories.
  4. Click System Tools .
  5. Click Disk Clean up.
It will scan your files then a box will pop up.
check all the boxes and click next.
This will clean up your computer and help it to move faster. Now you follow the same instructions but this time you click on Disk defrag.
Click on Defrag to start the Defragging .
Do this as soon as you get the computer on desk top.
Nov 26, 2009 | Computers & Internet
Loadsbut can not open any programs even the start
Your operating system files may be damaged try restoring your PC to older dates so that it will restore to the old date when your laptop worked proper ly.
Oct 21, 2009 | Acer Aspire One PC Notebook
Thinkpad R40 find date & time for start-up
Right-click the time in the lower right, select: adjust date and time, select: internet time, select either source, select: apply (if high lighted)--otherwise close. You need to be connected to the internet for the internet time to work.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Clearing the date on my faxes
Go to the menu options in your fax machine and select show date and click no
Nov 21, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
My fuckin junk computer
you could use the System Restore option( Start->programs->accesories->system tools->System restore)
1.select restore my computer to earlier time
2.Click the date before the installation of those wrong updates and next
note: all programs installed after the specified date would get uninstalled
May 20, 2008 | Fujitsu ATI RADEON (64 MB) Graphic Card
How to move entries that are place in wrong chronological order in payments section
Most mature programs would do that as well as check to make sure the date format is consistent. Since I don't know what program you are using that's all the information I can give you.
Jan 20, 2008 | Computers & Internet
pangolin QuickShow Laser Light Show Computer Software: Enttec DMX USB PRO Device DMX Trigger Logo
21 people viewed this question
Top pangolin Office Equipment & Supplies Experts
jasbo
jasbo
Are you a pangolin Office Equipment and Supply Expert? Answer questions, earn points and help others
