Leaks water from underneath
SOURCE: LG fuzzy Logic 5.5 WF T552
check drain to see if plugged. if it can't spin water out, it will shut down.
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
SOURCE: I'm using LG Fuzzy logic 6.5kg WF-S6607TC.
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
SOURCE: lg fuzzy logic 6.5kg WF-T652A OE error. have
Hi Rylee
Thanks for using FixYa. Error code OE means that the pump is blocked and signal
is being sent by the control panel to the washer that the water isn't draining properly.
Please also check that the washer is leveled properly, pump is not blocked with
any foreign object, drain hose is not blocked and drain pump filter is clean. Please
accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
