Question about Refrigerators
Digicode 5040 garage door opener works in the garage but not outside of the garage
Door Tech
  • 98 Answers
SOURCE: Remote will not operate garage door opener from outside garage
Will the remotes work in the garage? If yes but not outside with the door closed you might have radio interferace with your remotes. You might have to chage to a your reciever and remotes to a different brand (frequency). Sometimes it is less trouble to change out the operator. Chamerlain changed frequency from 390 (old) to 315 (new).
Posted on Jan 02, 2009
Doorguy27
  • 30 Answers
SOURCE: Keypad outside not working Properly
Have you replaced the battery in your keypad? That should take care of the trick.
Posted on Feb 10, 2009
glenmann62
  • 91 Answers
SOURCE: Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Posted on Mar 04, 2009
  • 244 Answers
SOURCE: Opener stuck in "lock" position
Recode keypad and remotes
Posted on Dec 29, 2009
swolfinor
  • 504 Answers
SOURCE: remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Posted on May 30, 2010
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: outside keypad will not open garage door at all bu...
The inside button is hard wired. The keypad is a small radio transmitter. If the battery in the keypad is good and it doesn't work when you put in the code it has probably just quit.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a new crastman garage door opener. Both clickers work inside the garage but outside the garage when the door is closed you have to click it like ten times for it to finally open. The wireless key...
Have you tried adjusting the antenna position? If you can't find a good position for the antenna, you may want to extend it and bring it close to or outside the garage door opening.
Mar 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hi I have a sears craftsman garage door opener. I initially replaced the outside opener with a CLK1 - it worked fine after a chat to clickerproducts. Now I have replaced both the car remotes and no matter...
It sounds like you bought the wrong car remotes. The model number for your opener is on the end closest to the garage door. Using it you can get the correct remotes.
Jan 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a crafsman opener #139,53879. Installed an outside remote on door and now the factor opener will not work.
Sounds like your outside remote may be the wrong one for your opener. Program your original remotes and you will most likely find your outside remote will not work. The model number for your opener is on the opposite end of where all those white wires go. Use it whenever you need to buy anything for your opener.
Dec 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
My garage door opener only works from inside the garage
try repositioning the antenna that comes off of the opener. make sure there are no obstructions around it
May 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door shuts down, need to press reset to get it to work
On the side of the opener you will find the down limit control. Turn this a bit in the opposite direction of the arrow printed on the cover. You will probably have to tweak it a bit to get it just right.
May 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
