Question about Bosch Dishwashers
Bosch ascenta one year old wont start - Bosch Dishwashers
3 Suggested Answers
SOURCE: Bosch Ascenta SHE4AM1 Start any
i have the same problems..Did somebody tell you what to do to solve it?
Posted on Jul 25, 2009
  • 1214 Answers
SOURCE: Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on
by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press
ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each
program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended
and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end
shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Let me know what you figure out. I can repair these boards most of the time.
Posted on Dec 18, 2009
Need a Service Repair manual Bosch Ascenta she3ar56uc
You can get one here:
https://www.manualowl.com/p/Bosch/SHE3AR56UC/Manual/117427
Sep 22, 2015 | Bosch Washing Machines
Bosch dishwasher door pops open during cycle
Latch needs adjustment or replacement.
Jul 07, 2015 | Bosch Dishwashers
My bosch dishwasher is stuck on a cycle, it keeps on flashing and won't start
try shutting off the power at the breaker panel and wait a minute sometimes rebooting will clear up a problem
Oct 27, 2014 | Bosch SHE6AP15UC Ascenta Evolution Series...
Where is the thermal fuse
Go to Utube and copy and paste this in : Bosch dishwasher thermal fuse replacement location . You will be able to fix it yourself with the videos .
Here is the link :
https://www.youtube.com/results?search_query=Bosch+dishwasher+thermal++fuse+replacement+location
Hope this helps , Grant
Aug 11, 2014 | Bosch SHE3AR75UC Ascenta Series 50 dBA 62...
I am just looking for the decible rating on the bosch shu5306uc. Can you help? MINE IS ALMOST TEN YEARS OLD AND HAS STOPPED WORKING AND WOULD LIKE TO REPLACE WITH SAME DB LEVEL OR BETTER WITHOUT...
Welcome to FixYa.
I see your post is roughly a week old, but I`ll post an answer anyway, hopefully you`ll see it.
The SHU53** series Bosch dishwasher has an advertised "silence rating" of 52dB via the AVSĀ² insulation system.
By today's standards you should be able to purchase a $500 or $600 Bosch Ascenta SHX3AM02UC with a "silence rating" of 53dB.
Hope that answer's your question. Thank you for choosing FixYa.
Please take a moment to rate this answer accordingly and leave a testimony if you feel it`s warranted.
Good luck.
Regards,
Macmarkus :)
Sep 06, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Dishwashers Logo
14 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
