Question about Alesis Roadfire 15 AC DC Guitar Amp w/ 80 Digital Fx
Replacement battery alesis roadfire 15 amp
Battery died in above cited amp - can't find any info on what and how to replace.
No sound blank screen has power not used for 5 years product is a yamaha mm6 keyboard
Your battery has died and you've lost the sound info, Contact Yamaha in your area to find a service center to place the battery and reload the data.
Jan 24, 2017 | Yamaha Music
Does the alesis sr 16 have a back light on the screen
yes, it should light up when you turn it on. Make sure you have the right adaptor. The voltage & polarity will be wreitten on the unit. My adaptor is from Alesis. You can find these on ebay.
Jul 09, 2014 | Alesis Sr 16 Stereo Drum Machine
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
Alesis how to
Not much info, what type of alesis unit is this?
Mar 14, 2014 | Music
Blinking standby light no power
When you turn the amp on, does all the tubes light up? please add more info to help you out.
Oct 07, 2013 | Bugera 333XL Infinium 120 w 3 Channel...
Alesis Quadraverb Q2. When I turn on Alesis Q2 the programs 1-100 preset are working but when I turn on programs 200-300 user It does not work. There is only "bad program" characters on display.
The Problem is a dead battery which is soldered to the circuit board inside the unit. It's a Panasonic BR-2325-1HC, but really you can replace it with any similar 3V battery.
Here's how I fixed mine.
http://andrewapeterson.com/2013/08/fix-alesis-q2-first-made-strange-sounds-then-bad-program-issue-quadraverb-2-battery/
Feb 07, 2013 | Music
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
I have a Williams Encore Digital piano. When I power up there is no sound. Upon power up there are 8 small rectangle on the LCD screen. 7 red light are lit. They are the 4 lights above the "user...
Holding the page up and down buttons while powering on supposedly resets it. I have no sound except demos, but no lights showing like yours, and williams tech support said to reset that way but it didn't seem to do anything. Good luck hope this helps!
Jun 27, 2011 | Williams Encore Digital Piano
These subs arent loud
The subs are rated at 133 Db peak... that IS loud. Note that the crossover is 90Hz so ONLY the very low frequencies will pass through these... possibly your input frequencies are above this? Everything above F2 will be attenuated and will have to go through other speakers. From this chart:
http://www.google.com/imgres?imgurl=http://ehartmusic.info/wp-content/uploads/2010/12/frequency_chart_lg.gif&imgrefurl=http://ehartmusic.info/music/music-frequency-chart/&h=709&w=1026&sz=61&tbnid=lLcM8uGqj673QM:&tbnh=104&tbnw=150&prev=/search%3Fq%3Dmusic%2Bfrequency%2Bchart%26tbm%3Disch%26tbo%3Du&zoom=1&q=music+frequency+chart&hl=en&usg=__TpgHSTWoL_Wg1Q0T8gadkn8o_gE=&sa=X&ei=sZWzTdLqOcrjiAKrrf2uBg&sqi=2&ved=0CBsQ9QEwAQ
You will notice that ONLY the LOW END portion of a bass guitar and a few other instruments will oass through this unit. It is up to your mains to handle things above 90 Hz. These subs are truly subs. Make sure you use balanced lines to drive these. (XLR)
Apr 23, 2011 | JBL PRX618S Speaker PA Sub
Alesis Roadfire 15 AC DC Guitar Amp w/ 80 Digital Fx Logo
Top Alesis Music Experts
drivealot
Lawrence Oravetz
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
