Question about Safe International Locks & Locksmithing
Secure handle bar - Safe International Locks & Locksmithing
How do I remove the bar end's on inside the handle
The ones on my Suzuki have screws in the ends these pull against rubber bushes and squeeze them to secure. To remove them loosen the screws and tap them back into the bar end. I believe some bar ends are screw fit in their own right. Twist clockwise to tighten anti clock to remove.
Sep 23, 2014 | Motorcycles
Raising handle bars
Right in the center of the handle bars you will find a nut ( usually allen key) that is in line with the tube going down/attached to the fork of the bicycle. Loosen this nut and unscrew it for about 5mm - don't remove it completely. Take a mallet and hit the nut firmly on its head to force it back the 5 mm unscrewed. It should release the tapered lock inside the tube and the handles can be adjusted. If it is still stuck, unscrew the nut more and repeat the process. After adjustment tighten the nut firmly, while holding the handles in position. It will lock again as it is getting tightened. Make sure it is secure by "clamping" the front wheel between your legs while trying to move the handles in any direction. Handle movement should not be possible when applying moderate to strong force. However, excessive force will result eventually in movement and or damage to the front wheel and is therefor not required.
Apr 14, 2014 | Magellan Cycling
How do you take cover for handle bar cover come off
Use your fingernail or a fine blade of some sort to pop the little caps out of the four allen head bolts that secure the clamp to the bars. Loosen the allen screws while being careful of the bars dropping once the bolts are loose.
Jul 31, 2013 | 2003 Harley Davidson FLHR Road king
I have a deniese austin manual treadmill and do not know how to open it
Dear Sir:
Thank you by your request, I will help you inmediately.
1) Unpack the carton. Place Main frame and Running track on a flat level floor.
Attach the post left and right onto the Main frame withthe Screw.
2)Attach the STABILIZER Stand with the post lef and right before mentioned 1) onto the main frame annd tightly secured with Screw/Nut.
3) Raise UP the post Left +Right mentioned Before in the section 1)
4) Inser the Handle Bar left +Right in the front Handle bar, then onto the post Left and Right mentioned into the section 1)
5) Put the computer unit onto the fron Handle Bar with Screw.
6) Raise the Main Frame and Running Track up, attach adjustable Rod with Screw Nut and lik Stabilizer stand tightly secure with screw nut.
Warning: On folding up the running track, do make sure que the pin lock knob are porperly enganged and securely tghten to prevent accident.
To unfold, Pin lock simply loose to pull out Knob and gently lower the Running Track.and Ready.
Thank you in advance, sincerely. God bless you.
If you need further assistance, please contact me
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Exercise & Fitness
Installation of new chain on 16 " chain
Make sure the chainbrake ( if if fitted ) is off by pulling the hand guard fully back to the top handle, remove the securing nuts and remove the side cover, wind the chain adjuster back if it is in the crankcase, pull the bar fully back, now loop the loose chain off the tip of the bar and over the sprocket, re fit the new chain over the sprocket, and lay it around the guide bar, place the bar adjuster hole onto the adjuster pawl ( if it is in the crankcase ) refit the side cover, if the adjuster pawl is in the side cover make sure it fits into the hole in the bar, put the securing nuts back on finger tight, adjust the chain so as it fits snuggley around the bar, with a gloved hand pull the chain around the bar to make sure it is seated correctly, re adjust if required, lift the bar nose up and fully tighten the securing nuts, after the first ten minutes of use re check the chain tention as there will be an initial stretch.
Jul 02, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
We purchased a Radio Flyer Stroll and Go but during assembly the front wheel was put on but was put on 90 degrees the wrong way. We are not able to get the wheel off so we can correct the wheel.
Where you inserted the handle bars into the bearing assembly on the frame there is a fork clamp you had to tighten to secure the handle bars and front fork. Loosen this and you should be able to disassemble the front end. While reassembling be sure the you line up the notches on the fork with the grooves in the bearing assembly and that the handle bars are properly aligned before tightening the fork clamp.
Apr 03, 2011 | Cycling
How do I securely mount a towel bar on a mirror?
My husband is a plumber. He says it's illegal to mount a towel bar on a mirror. People who do it illegally drill a hole thru it with a diamond drill bit. There has to be studs behind the mirror also.
Dec 30, 2009 | Moen Monticello Single-Handle Kitchen...
My daughter wrecked on her Mongoose r2261wm and now the handlebars just spin. We can't see any obvious breaks or loose/missing bolts. We're thinking it must be something inside the fork where the bar goes...
There should be a bolt on the frame at the base of the handle bar stem. There should also be a bolt on the top of the handle bar stem. If these are both tight and secure. The odds are the expansion clamp that's connected to the base of the handle bar (part that goes into the frame) has broken.
Aug 23, 2009 | Cycling
Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Oct 15, 2007 | Amana AFD2535DES French Door Refrigerator
Locks & Locksmithing Logo
23 people viewed this question
Top Safe International Locks & Locksmithing Experts
john h
Jay Finke
Jay Finke
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
